Results 1 to 10 of 11
Thread: Looking for some 12v in the doors
    Jan 2010
    Barnsley
    Trim : Irmscher Elite
    Engine : 3.0 CDTI
    Default Looking for some 12v in the doors
    Right, i have a 2005, preface, full canbus Signum and i'm looking to fit some LED strips as kerb lighting under the doors. I'm wondering, is there either a dimming (with the interior light) live, a switched (with the door opening/ closing) live, an ignition live or a live that switches with the lights? I think i've noticed that some Signums have a lit red marker in the back of the doors.....
    Mar 2009
    morecambe
    54 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Connect it to the door switchs mate u no when ya unlock ya car my door switches light up get the light feed for them o yes
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    They'll be on then whenever the car is unlocked. Only ideally want them on when the doors are open if poss.
    Nov 2010
    UK
    Engine : z18xe
    Year : 06
    Can you not connect to the wire paul said, then run one up to the switched -ve in the interior light? that was my plan.
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    I wanted to try and avoid running cables down from there, then splitting out and going to all the individual doors through the rubber conduit. It'll just turn into a mamouth job for just a few lights. I'm sure i've seen some signums with red 'door open' markers in the doors. Think i'm going to get the meter out and get the drivers door card off.
    Mar 2009
    morecambe
    54 Post(s)
    Vehicle : vectra
    Trim : vxr
    They won't Mate unless u use a relay
    Regular Member DTi Elite's Avatar
    May 2012
    county durham
    Engine : 1.9 cdti 150
    Mileage : 145k
    Had thought about doing something like this myself & gave it a bit of thought , there will be a permanent live feed to the electric window motors & I would expect there to be a switched earth in the wiring to the door latch as this is supposedly where the feed for the interior light comes from .
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    Hmmmm, a little light at the end of the tunnel.
    Regular Member bigdunk1985's Avatar
    Aug 2011
    Ellesmere Port, Cheshire
    Vehicle : Vectra C
    Trim : SRI Nav XP CDTI 150
    Engine : 1.9 150
    surely the switch that makes the interior light illuminate when the doors open would be a good place to wire in to
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    Quote Originally Posted by bigdunk1985 View Post
    See post #5 mate.
  1. Next doors vec dti
    By marc vectra sri in forum Vectra C / Signum Car Chat
    Last Post: 4th October 2012, 06:39
  2. Taxi Doors / Autolocking Doors
    By AntSSSS in forum Vectra C / Signum Car Chat
    Last Post: 17th April 2012, 19:05
  3. 4,,, Or 5 doors??
    By mitch1965 in forum Vectra C / Signum Car Chat
    Last Post: 2nd June 2008, 19:56
  4. How do you take the doors apart?
    By nutron in forum Vectra C / Signum Car Chat
    Last Post: 4th August 2006, 20:28
