Thread: Urgent helP with 2.0 dti signum
    Mar 2011
    wigan
    Default Urgent helP with 2.0 dti signum
    Basically I'm an idiot and have killed my car. I went through a flooded roundabout the other day to get to the shops. Went through and all was fine so off I go shopping. On the way back I went through the same flooded roundabout and when the car got out of the water it died within a few yards and I was unable to restart it (wouldn't even turn over). My dad gave me a tow and eventually I got it to fire and it now runs and starts. However I'm getting lots o smoke out of the back and have been for a few days. It stinks of diesel so I think it's overfilling. Drives really lumpy until about 3k then the boost kicks in like a tonne o bricks. (doesn't seem to smoke when in boost). I thought id hydrolic'd the engine but once it's in boost it runs smooth as always. Ive toyed a new egr valve and it just made the car feel quicker buys didn't go the smoke or the lumpy driving. I think it's boost related but I'm not sure. Any advice greatly appreciated.
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    give it a full service.
    no knocks or anything? brave towing it after it cut out after a puddle you risked damged con rons if it had hydroliked
    Mar 2011
    wigan
    It had a full service a few months ago. I thought I the engine had hydrolic'd it was a bin job anyway so I just went for it. There's a slight diesel knock at low revs but if I had ******ed a to or a valve it would be knackered throughout the rev range. To me it's Pouring diesel in thinking its on boost an running it rich an lumpy. Then at 2.7-3k rpm boost kicks in hard then all is well. Usually the boost kicks in at about 2k I think and you can't feel it. This you can feel. I was thinking an air leak and it's loosing boost pressure until 3k and then enough air is finally getting to the turbo to spin it up. But I dunno how water would have caused a leak
    Regular Member john norris's Avatar
    Jun 2012
    lancashire
    id be tempted to look round crank sensor ect see if theres any crap got stuck in there, happened to me once going through a flood (vec b) knocked the sensor back just far enough for it not to sense properly i didnt get a warning light because it was intermittent or so i was told
    May 2012
    county durham
    Engine : 1.9 cdti 150
    Mileage : 145k
    my guess is a slightly bent con rod .
  1. Urgent help needed, more signum problems :(
    By Shogun in forum Vectra C / Signum Troubleshooting
    Last Post: 29th September 2012, 20:45
  2. Urgent Help Needed please, Signum Elite 2.0T CIM/Dash/Electrical Problems!!!!!
    By robs_gsi in forum Electrical & ICE (including SatNav)
    Last Post: 28th April 2012, 10:43
  3. Urgent advice - Signum 1.9cdti clutch smell
    By pscocoa in forum Engine & Drivetrain
    Last Post: 2nd August 2008, 11:41
  4. urgent help needed re signum and dealer
    By merikiito in forum Handling & Braking
    Last Post: 10th January 2008, 01:13
  5. Signum Front Fog Lamps..urgent Help Needed!
    By CARRERA in forum Bodywork & Interior
    Last Post: 5th September 2007, 08:51
