Results 1 to 10 of 13
Thread: Turbo Fail????
    Aug 2012
    Default Turbo Fail????
    Hi Guys,
    So I just bought my first Vectra, a 05 SRI 120. It has until now made a kind of hissing whistle that can be heard as it hits 2000 ish rpm. Anyway as of today it made a kind of jolt while driving then got nosier. It now make a "distant police car sound" when sat still and revving the engine. The aux belt returns to normal speed and the sound continues to wind down so I am pretty sure its noise from the turbo.
    On the front near the slam panel is a little Vac Valve and I have removed both these pipes and it still does it. I only have to rev a little to get the noise to start (less than 1500). The harder I rev the longer and louder it is.
    I did clean the MAP sensor a few days ago but have no fault indications even now and if I disconnect it I get a fault so it seems ok.
    I am not sure if its a blown pipe or a blown turbo but would appreciate any help or suggestions.
    I have disconnected the large pipe that connects the inter cooler to the manifold and it has a thin layer of oil on its inner surface but this was there before the incident which made it noisy so not sure if this is normal or maybe relevant.
    Please help me :-)
    Jun 2011
    wolverhampton
    Id say sounds like s split boost hose. Check all hoses from the turbo to the cooler then to the intake manifold
    Aug 2012
    Quote Originally Posted by sriandy View Post
    Thanks for the reply. I hope it is something this simple. I have checked all the hoses I can see and can't see any damage. Maybe I need to get underneath. Without a Haynes to tell me whats what its dificult to know which pipes I should check.
    Anyway the noise is identical to this http://www.youtube.com/watch?v=yoGm_1tK0kk
    Regular Member carperjake's Avatar
    Scunthorpe
    Trim : Elegance CDTi 120
    Engine : 1.9
    http://www.vectra-c.com/forum/showth...ght=boost+hose
    Have a look at this thread, lots of info that seems to relate to your problem.
    Regular Member john norris's Avatar
    Jun 2012
    lancashire
    i was told the distant police car sound was the blades in the turbo hitting the case worn turbo my car is also making the same noise now im wondering if i was being blagged in to a new turbo
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Sounds like turbo is goosed to me
    morecambe
    44 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    If it makes alot of smoke and it's like hitting a limiter at 3000rpm turbos gone
    South Central England
    10 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    Lots of oil in the pipes is normal due to the crank case vent.
    If it makes the noise with the vacuum hose disconnected then it is less likely to be the turbo and more likely to be an exhaust leak.
    Turn on the car when it is cold and feel around the trubo manifold and the egr valve to see if there are any exhaust leaks.
    These could come from a blown gasket, cracked manifold, split pipes in the EGR system.
    Does it still drive normally?
    Jun 2012
    lancashire
    mine pulls fine a little lag before turbo kicks in but swirl bar has dropped of so that will be the reason for the lag there i get a little white smoke untill its warmed up first 5 mins ten its fine
    i was debating on getting a kit to rebuild turbo but its balancing im worried about
    Aug 2012
    Quote Originally Posted by nutron View Post
    Mine still drives as it always has since having it. This would be a little under powered in my opinion till about 2000 rpm then a real pick up after that. This could be normal as I am downsizing from a 3.0 bmw which was rapid.
    This noise has not been a gradual thing it was fine and then loud during the same drive and instantly. It wasn't like the noise has got worse over days or gradually faded in while driving.
    If I disconnect both the hoses connected to the slam panel solenoid it makes no difference to the sound that you hear when just revving the engine, I still get the noise in the above video. I haven't tried it under load / while driving.
    I removed the EGR to see how bad it was and this was the result
    Anyway I cleaned it up and refitted but still the same noise so leak is unlikely to be there. I am going to get it up on jacks on sunday and check all the pipes and I am going to do as this thread suggests and see if I can cure the under powered feeling below 1500rpm http://www.vectra-c.com/forum/showth...ght=boost+hose (anyone interested will have to read from about page 12 onwards)
    Heres hoping I find a leak as other than the noise and a bit of hesitation under 1500 it drives well with no smoke
    Thanks for all the responses everyone I appreciate all of your time
    James
  1. Turbo fail.
    By JM53 BEL in forum General Motoring Chat
    Last Post: 3rd February 2013, 20:38
  2. Cdti silicon intercooler pipes fail ! No turbo?
    By Elahi_786 in forum Engine & Drivetrain
    Last Post: 30th March 2012, 00:22
  3. HELP With M.O.T FAIL!
    By corderz in forum Vectra C / Signum Troubleshooting
    Last Post: 25th May 2011, 09:23
  4. Turbo Technics fail miserably
    By nutron in forum Diesel Engine related
    Last Post: 9th January 2011, 01:36
  5. Will it fail an M.O.T ?
    By The Gas Man in forum Vectra C / Signum Car Chat
    Last Post: 8th November 2007, 00:14
