Page 1 of 5 123 ... LastLast
Results 1 to 10 of 41
Thread: Flashing Spanner
    Full Member Knight Rider's Avatar
    Apr 2008
    Motherwell
    Vehicle : Vectra C SRi 1.8vvti
    Trim : Sri
    Engine : 18.vvti
    Mileage : 29,500
    Default Flashing Spanner
    Went to start the car up after placing out my reverse sensors and control box which I've hooked up to earth and reverse light wire I had the ignition on whilst doing it then went to start the car up up and nothing except a flashing spanner/car symbol. Do you reckon it's just needing a jump start to get it going again after having the ignition on?
    wirral
    39 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Is it turning over?
    Apr 2008
    Motherwell
    Trim : Sri
    Engine : 18.vvti
    Mileage : 29,500
    Quote Originally Posted by Critch View Post
    Is it turning over?
    Nothing a tall mate, all my dash lights come on but no turn over
    Regular Member monty2000's Avatar
    Sep 2009
    swansea
    Vehicle : Vectra C Pre Face, Colour Coded, CR Tech Box, Pipercross Panel filte, Blanked EGR :-)
    Trim : Club
    Engine : 1.9cdti 16v
    maybe a longshot but i removed my tcs fuse in attempt to disable the traction and my car wouldnt start.
    check the fuses
    wirral
    39 Post(s)
    Trim : Basic
    Engine : 1.6 16v
    Not pulled away wires whilst doing it?
    Are the dash lights staying bright?
    Apr 2008
    Motherwell
    Trim : Sri
    Engine : 18.vvti
    Mileage : 29,500
    Quote Originally Posted by monty2000 View Post
    check the fuses
    Ok will do
    Just the 2 earth cables underneath the near side brake light for an earthing point but I've tightened them back up again.
    Yes as far as I can see mate.
    Apr 2008
    Motherwell
    Trim : Sri
    Engine : 18.vvti
    Mileage : 29,500
    All fuses have been checked and they're all OK. My voltage gauge on my dash is showing just under 11 so I'm guessing this might be the cause.
    wirral
    39 Post(s)
    Trim : Basic
    Engine : 1.6 16v
    More than likely the batt issue of its reading 11v
    Gettong a starter relay click when trying?
    Apr 2008
    Motherwell
    Trim : Sri
    Engine : 18.vvti
    Mileage : 29,500
    Absolutely nothing mate when I turn the key. Dash does everything it should do when key is in.
    wirral
    39 Post(s)
    Trim : Basic
    Engine : 1.6 16v
    Do you have any diagnostics?
    Try disconnecting batt for 15 mins
  1. Replies: 23
    Last Post: 31st August 2012, 11:52
  2. flashing spanner and wont start
    By jofenan in forum Engine & Drivetrain
    Last Post: 3rd February 2011, 13:52
  3. flashing car and spanner light
    By signumturbo04 in forum Vectra C / Signum Car Chat
    Last Post: 17th July 2010, 16:32
  4. The "flashing car picture with spanner through it" light
    By Big Dave in forum Engine & Drivetrain
    Last Post: 9th February 2008, 04:33
  5. flashing spanner light
    By carp in forum Engine & Drivetrain
    Last Post: 27th April 2006, 14:53
vectra c 1.8 spanner and car light flashing
