Results 1 to 3 of 3
Thread: Do I need a Wiring Harness?
    May 2012
    Cambridge
    Default Do I need a Wiring Harness?
    Hi guys,
    I've got an '03 Vectra, 3 buttons on the steering wheel so I assume half canbus.
    I'm after replacing the standard CDR2005 with a Pioneer AVH-1400DVD. As far as I can tell, am I right in thinking that this will simply plug and play using the ISO cable in the box?
    I am under the impression that the half canbus vectras are all ISO anyway. Is this correct?
    I don't particularly care about the buttons on the steering wheel working. It would be nice, but I have no clue as to which cable I would need.
    I also know I need a face plate adapter, possibly this T123VX11A http://www.amazon.co.uk/T1-Audio--T1...6758184&sr=8-1 I'm not sure.
    If I can get away with just buying those two items (and a head unit removal tool) I'll order asap.
    Any help appreciated.
    Weid
    Regular Member john norris's Avatar
    Jun 2012
    lancashire
    looking at the photos on here there must be a harness in the box to take it to iso connection
    http://www.bassjunkies.com/av-sat-na...er-avh-1400dvd
    i had an 03 vectra and it was iso connectors i bought an adapter for the steering wheel controls and if i remember correctly the memory wire and the +12V are reversed on vauxhall as opposed to the standard iso you can get an adapter harness for that or cut the wires id buy the harness my self
    Item number: 350517856045 this is the harness on ebay should retain steering wheel controls and should be correct for the crossed power/memory
    Item number: 400317687971 Double din face plate stereo should have its own cage ect i dont know the colour of your dash so make sure you check that
    Jun 2012
    lancashire
    for got to add stereo just has 4 grub screws in the front, remove them then use small allen keys or like me cut some spokes of an old bike wheel push em in the holes then spread them outwards and pull the stereo out all at the same time
    i have found running wires to the back for amps and fitting head units ect easy in the vectra c simple easy access compared to most cars i have done
  1. Tailgate wiring harness
    By troutybrown in forum Bodywork & Interior
    Last Post: 22nd January 2012, 13:00
  2. How do i know which wiring harness i need?
    By caigey in forum Electrical & ICE (including SatNav)
    Last Post: 28th July 2009, 21:49
  3. Roof Wiring Harness - Please help ...
    By hans_vledder in forum Electrical & ICE (including SatNav)
    Last Post: 23rd December 2008, 10:54
