Thread: Signum Blower Woes - Fuse Replaced...still broken :(
    Aug 2012
    Rugby, Warks
    Default Signum Blower Woes - Fuse Replaced...still broken :(
    So, I bought a Signum a couple of weeks ago and noticed that the blower only works on number 4 setting. After a bit of googling i managed to find the solution to this common problem on this excellent forum.
    I removed the glovebox, followed by the resistor pack, and ventured to Maplin to find a replacement thermal fuse. The helpful chap promptly found one for me, and I screwed it in, plugged the connector back in, and switched the fan on to find....
    It still didn't work!
    Where do I go from here? The new fuse has continuity (as does the old one, so it would appear).
    Do i need a new resistor pack or does the problem lie elsewhere?
    Thanks in advance!
    James
    midlands
    Hello
    Exactly the same happened with me - 2 years ago thermal fuse blew replaced and all was well - 2 months ago went again replace the fuse, not working so had to buy a resistor pack of ebay for a tenner - now works. I think the electrics just stop working and need to be replaced
    Aug 2012
    Rugby, Warks
    Quote Originally Posted by steve533 View Post
    Hello
    Ah, i was wondering if that could be the case. both fuses are fine. so you just replaced the whole green resistor pack and it worked again?
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 141000
    Aug 2012
    Rugby, Warks
    Thanks, sounds like a good job for the weekend.
  1. Signum Blower/Fan Only Works on Speed 4
    By Gayno in forum Electrical & ICE (including SatNav)
    Last Post: 15th April 2012, 13:31
  2. 2.0 T signum lambda woes
    By Rasher in forum Electrical & ICE (including SatNav)
    Last Post: 9th April 2012, 18:40
  3. Heater blower replaced
    By jonny747 in forum Vectra C / Signum Troubleshooting
    Last Post: 18th May 2011, 17:09
  4. Should Vauxhall Pay For Replaced Blower and/or Resistor Packs
    By iandavis in forum Vectra C / Signum Car Chat
    Last Post: 27th August 2010, 11:52
  5. Signum woes
    By Hs2300 in forum Engine & Drivetrain
    Last Post: 3rd March 2009, 22:51
