Thread: Kenwood DPX-503U Double Din
    New Member Blueandwhite's Avatar
    Aug 2012
    Coleraine
    Default Kenwood DPX-503U Double Din
    I've recently bought the above Double Din unit to replace the factory unit. On inspection the "cage" of the new unit looks deeper than the factory cage and wont fit.
    Anyone have a similar problem?
    Regular Member stuart bigboy's Avatar
    May 2007
    kent
    you need to take the oem cage out 1st
    Aug 2012
    Coleraine
    I have done. The cage on the Kenwood unit is approx 5 to 6mm larger in height than the original
    Northumberland
    Hi Blueandwhite
    Its just the question I was goint tp ask. Mines a JVC AW60BT and although the unit is smaller than the aperture the cage it too tall for the aperture. I can see why as the cage has a receess where it grips the top of the unit. Its not entirely flat like the single din cages. I have heard of things called cage kits. I wonder if someone might be along to confirm what needs to be done.
    Tim
    Regular Member braby's Avatar
    Watford
    You need to get a fitting kit to fit an aftermarket stereo, this replaces the cage that comes with the stereo and has the fasica with it as well. http://www.connects2.co.uk/c2search....=233&modID=875.
    It should show the colour you need on the top of the factory radio when you remove it.
    Aug 2012
    Coleraine
    Thanks folks ordered a kit today and its been despatched!
    Northumberland
    I'll be doing the same!!
    Tim
  1. kenwood double din
    By coolj in forum Electrical & ICE (including SatNav)
    Last Post: 21st April 2012, 01:16
  2. kenwood double din £80
    By shoota70 in forum Vectra C / Signum Car Chat
    Last Post: 19th February 2012, 21:28
  3. For Sale: Kenwood Kenwood DPX-503U Double Din CD / MP3 / USB player AND Fascia!
    By John LE in forum Parts for sale
    Last Post: 3rd December 2011, 13:49
  4. Kenwood DPX-503U
    By monkeez in forum Electrical & ICE (including SatNav)
    Last Post: 4th March 2009, 21:13
  5. kenwood double din
    By stuart bigboy in forum Parts for sale
    Last Post: 29th June 2008, 17:13
