Results 1 to 10 of 17
Thread: Tech 2 needed in bridgend s-wales
    Regular Member neil0748's Avatar
    Jan 2008
    Bridgend s-wales
    Default Tech 2 needed in bridgend s-wales
    Hi is there anyone with a tech 2 in south wales i live in bridgend i need someone to programme two front crash sensors that i have bought to the ecu on a vectra c 03 plate, i will pay someone to do it the stealers want £110 for fitting i would be mostly greatfull thanx.
    Administrator plasma's Avatar
    On the Forum
    398 Post(s)
    Engine : 150
    Mileage : 74000
    the front crash sensors dont need programming mate, its probably the airbag ecu probably needs crash codes clearing?
    can you share the story to bring you to this situation?
    Jan 2008
    Bridgend s-wales
    Hi plasma vauxhall have fitted a new sim and airbag module but they said it needs two new crash sensors so i have bought two new sensors do they need to be programmed cos if not i can do it myself i have done it before
    Jan 2008
    Bridgend s-wales
    Vauxhall have checked the wiring to the sensors and they are ok it's just the ecu cant find the crash sensors because they are saying they are faulty.
    Jan 2008
    Bridgend s-wales
    Plasma if disconnect the battery for an hour and replace the old with the new will it work.
    On the Forum
    398 Post(s)
    Engine : 150
    Mileage : 74000
    Once you disconnect the battery give it 5mins for the airbag system to discharge and then unplug the sensor (these are the rectangular ones adjacent to either headlamp you are referring to correct?) and then plug in the replacement, they are a little fiddly to do as u need a really small female torx socket. If vauxhall are correct this should sort your problem, but not known these to play up really....
    why did they replace the CIM and AIRBAG ecus?
    Jan 2008
    Bridgend s-wales
    Diagnostics were saying the ecu or the module could not talk to the sim one or the other cant remember now so i replaced the whole lot.
    Jan 2008
    Bridgend s-wales
    I know of a mate of mine in vauxhall so he got the parts for me cheap.
    Jan 2008
    Bridgend s-wales
    I will give it a try later if it doesn't work i will let you know plasma .
    On the Forum
    398 Post(s)
    Engine : 150
    Mileage : 74000
    ok mate, keep us informed
  1. Any body in north wales chester area with tech 2 or opcom.
    By paulcdti150 in forum Electrical & ICE (including SatNav)
    Last Post: 28th February 2011, 21:56
  2. Tech 2 Help Needed Please
    By Bethan39 in forum Vectra C / Signum Car Chat
    Last Post: 22nd May 2010, 13:10
  3. anyone with tech-2 in n wales help
    By shakey in forum Vectra C / Signum Car Chat
    Last Post: 21st January 2010, 00:28
  4. tech 2 needed
    By mhvcbv in forum Electrical & ICE (including SatNav)
    Last Post: 9th March 2009, 14:23
  5. Tech 2 Needed - Yes / No
    Last Post: 11th February 2009, 22:42
