Results 1 to 10 of 11
Thread: Battery and charging etc....?
    Carnoustie
    confused Battery and charging etc....?
    Having some further problems having recently purchased this car, it's a 2007 vectra 19cdti estate 150 Elite
    was using the car today running about a few decent runs nothing on bar the radio, seems later the car was struggling to start! turning over slowly as if battery flat, 2nd attempt turned over faster.
    When I got home I stuck the charger on it, was drawing 5amps on low charge, but the indicator on battery is green.
    I done the timing belt on Friday full kit inc water pump and a new aux belt tensioner.
    I'm suspecting the Alternator? when running voltage goes no higher than 13.8 even with a rev, previous owner claims alternator was recently changed and it does look newish! I'm wondering if an 105amp was fitted instead of 140amp, also noticed with a rev there is a whiring noise might be from Alternator, just not sure where to go with this? battery, Alternator or starter motor?
    Any advice very welcome.
    Carnoustie
    Anyone?
    Regular Member john norris's Avatar
    Jun 2012
    lancashire
    I once had one of these newer calcium battery's and I managed to flatten it a couple of times I had it on charge over night and it would not keep its charge even though the battery indicator was green, turns out that you need a special charger for these battery's and once there flat they are very difficult to resurrect
    mine was only starting because the capacitor i had for the amps was chucking power back down to crank the engine lol
    Carnoustie
    Quote Originally Posted by john norris View Post
    Looks like mine still has original GM battery fitted, but you would think if the Alternator was doing it's job it would keep it topped up during the day?
    Jun 2012
    lancashire
    they wont always keep the charge if its the original it is 5 year old they normally come with a 3 year warranty id change the battery tbh if its just to check might be worth grabbing one from the scrappers see how that goes but sooner or later id put a new one in
    if you can see the alternator stickers if i remember correctly the amps are written on it
    Mar 2012
    Dundee
    Vehicle : GSI
    Trim : (vxr/irmy)
    Engine : 3.2 v6
    Like my battery it wouldnt keep a charge i just got a new battery and now its fine
    Carnoustie
    I see what your saying guys but my money is on the Alternator! I did a 10 mile run and put charger straight on charge it was drawing 5 amps on trikle charge, 2 hours it was fully charged, did not loose charge overnight, if Alternator was doing it's job I would say it would keep battery topped up?
    cheers Ronnie
    Dec 2011
    Seaham
    Put a volt meter across the battery, at rest it should read 12.6v, start the car, the alternator should push the voltage up over 14 volts, add some load, lights on etc, see what the voltage reading is now, it should still be around 14 volts.
    If you still have doubts get the battery tested at a garage, they put on a load test and can also do the same with your alternator.
    Carnoustie
    Quote Originally Posted by Ben50n View Post
    Thanks I did put the meter across battery when it was idling no load just radio, 13.5 then jumping 13.8 and back down, never tried battery alone, I did notice when I had the belts off spinning the alternator by hand there was a tick noise from it?
    Dec 2011
    Seaham
    Get the alternator professionally tested, that is the only way to know for sure. It does sound like it is a little bit low.
  1. Battery charging advice needed please
    By ijk571 in forum Electrical & ICE (including SatNav)
    Last Post: 30th December 2012, 22:34
  2. Advice on battery charging
    By olid2002 in forum Vectra C / Signum Car Chat
    Last Post: 18th May 2011, 21:21
  3. battery not charging on signum
    By superjetandy in forum Electrical & ICE (including SatNav)
    Last Post: 4th March 2011, 17:01
  4. battery not charging on signum
    By superjetandy in forum Vectra C / Signum Troubleshooting
    Last Post: 28th February 2011, 19:21
  5. Charging a battery
    By R13hard in forum Vectra C / Signum Car Chat
    Last Post: 11th November 2008, 14:24
what should a vectra c charging volts be
