Results 1 to 10 of 28
Thread: P2279 Fault Code - Ait Intake Leak
    West Midlands
    Default P2279 Fault Code - Ait Intake Leak
    Ok, finally getting somewhere I think with my on going fault of having no power below 2k, then all fury and a cloud of black smoke! Bought a new MAF sensor today (Bosch one) no difference. Starting to get a little hacked off, so trying all sorts of things I had my foot buried on the throttle in 4th, at about 25mph going up a slight hill, alot of black smoke and it went into limp mode, which to be honest was a brilliant result! Got home hooked it all up and got P2279 as the code. So far (in no particular order) I've done the following over the past few weeks.
    Swirl flaps bonded open at the 10 o'clock position
    New MAP/Boost Sensor
    EGR Blocked off
    New MAF
    Boost pipes changed
    BCS Filter removed
    Throttle Body cleaned and inspected the electrics for any dry joints
    I'm coming close to calling it a day, I spent £620 on Friday having the clutch and DMF replaced. Another £120 today on a MAF, plus various other things that have given up on this the past few weeks (air con pump, rear springs, alternator). My gut feeling is to sell it on, and it can be someone elses problem, I use this for my business and doing 50k+ a year I need something thats a 100%, I had a Skoda Superb 1.9TDI before this that I did 50k in, and apart from a £9 coolant sensor it never gave me any trouble on this scale. I changed to the veccy as it looks a fresher car, I had an estate before as a company car and loved it. But before I do is there any other suggestions on easy things to check, turbo's, intercoolers etc is where I draw the line as it starts going into stupid money!
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 141000
    West Midlands
    But surely this wouldn't affect it with the egr blanked off?
    West Midlands
    Another thing I noticed with the engine idling the 3rd swirl flaps sits at the 2pm position if that's of any relevance?!
    Regular Member wildchild's Avatar
    Sep 2011
    west-mids
    Vehicle : vectra c
    Trim : elite
    Engine : 1.9 cdti 16v 150
    Year : 06
    Mileage : 111250
    Hi mate does no3 flap return back to 10oclock when engine off n do you need to use opcom
    gaz
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 141000
    give the EGR Valve solenoid strip and clean
    http://www.vectra-c.com/forum/showth...ult-code-P2279]
    as in post 8
    West Midlands
    Wildchild, got op com coming tomorrow, an yes it goes back to the 10 o'clock position with the engine off.
    Ste I'm still not sure what this will achieve with the egr blanked off but I'll give it a shot!
    Sep 2011
    west-mids
    Vehicle : vectra c
    Trim : elite
    Year : 06
    Mileage : 111250
    Hi m8 i would try taking the blanking plate off the egr just to eliminate that one
    gaz
    Sep 2011
    west-mids
    Vehicle : vectra c
    Trim : elite
    Year : 06
    Mileage : 111250
    Just read last post but your more than welcome to put mine on if for any reason yours doesnt come oh n gonna pm you buddy
    gaz
    West Midlands
    Must admit never noticed a difference with it blanked off, just did it as a matter of course.
  1. Air In intake Leak fault CDTI 150
    By rollercoaster63 in forum Vectra C / Signum Troubleshooting
    Last Post: 26th August 2012, 21:00
  2. Fault code P2279?
    By Phil MC in forum Engine & Drivetrain
    Last Post: 8th July 2012, 19:29
  3. 1.9 CDTI fault code P2279-11
    By mozzer99 in forum Engine & Drivetrain
    Last Post: 14th June 2011, 20:13
  4. fault code p2279
    By decks in forum Vectra C / Signum Car Chat
    Last Post: 20th November 2010, 20:14
  5. Fault code P2279 Showing.HELP!!!.Info PLEASE.
    By felixx in forum Engine & Drivetrain
    Last Post: 28th October 2010, 18:34
p2279 fault code www.vectra-c.com
p2279 vauxhall astra 1.9tdi
P2279 VAUXHALL
