Results 1 to 2 of 2
Thread: EGR Screws issue?????
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Trim : Smart and Bad!
    Mileage : 105000
    Default EGR Screws issue?????
    ok. i did the EGR valve and cleaned it up. when i put it back on to the engine. the screws goes in then carries on going round as if the bit have now worn out. what can i do to fix this?? to make it tight again??? (Think the past it been done too many times or the person before i got the car from over-tightened it!!!
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    You can helicoil new threads into it, pretty easy to do in situ and the kits are quite cheap, about £20.
    You will need a 90 degree drill bit though, access is a bit tight.
  1. big screws
    By hippo in forum Vectra C / Signum Car Chat
    Last Post: 14th February 2012, 15:28
  2. Air Box screws
    By irmscherTI in forum Diesel Engine related
    Last Post: 2nd June 2007, 20:56
