Thread: 1.8vvt engine
    Aug 2012
    west bromwich
    Default 1.8vvt engine
    hi
    i have z18xer engine what the oil light is coming on and when the engine warms up and when i rev it its makes a knocking noise just wondering what could be causing it any help would be usefull
    thanks
    Regular Member VVT-i-MATT's Avatar
    Feb 2012
    Calne UK
    Low Oil Pressure....
    Stop revving it that's the first thing. That isn't helping.
    What grade oil is in there, and is this a newly acquired car?
    What's the mileage?
    Is the oil level OK?
    Is the knock at the bottom of the engine, or is it more a clatter at the top?
    Low on Power, or any smoke?
    Sounds like it's worn bottom end to me mate... but need more info.
    Matt
    Regular Member Angel1368's Avatar
    Mar 2012
    liverpool
    16 Post(s)
    Trim : VXR
    Engine : 2.8 V6 turbo
    Mileage : 44,000
    sounds like what happened to me i ran low on oil and starved the top pulley of oil and knackered it so needed that pulley replaced and also a gasket that was the cause of the oil leak
    Aug 2012
    west bromwich
    the oil is 5/30 fully synthetic long life the mileage is 125,000 the oil is on the max no smoke dont seem to be low on power i brought it a couple of months back with the head gasket gone i done the head gasket and had the head skimed and change temp sensor and its sound like the bottom whats knocking it only does it when its warm
    Feb 2012
    Calne UK
    Quote Originally Posted by Angel1368 View Post
    That sounds like a much more optimistic prognosis!
    Mar 2012
    liverpool
    16 Post(s)
    Trim : VXR
    Mileage : 44,000
    ill just look my dictionary up lol
    Feb 2012
    Calne UK
    Quote Originally Posted by ste20061 View Post
    I see, The oil grade is OK for that Engine.
    Given Power, and no leaks, that might rule out oil starvation unless there is a blockage in the system. As Angel Mentioned the valves on the VVT can stop working and cause a clatter/Knock. Get these checked out, esp at 125k
    Does it sound like a DERV when started from Cold?Is there a top end rattle/clatter?
    As the oil warms up it thins out, and this engine does run hot compared to he others. (It's not uncommon to see the test mode temp up past 107 Degrees C on normal running!!!)
    You might try a heavier grade oil. Maybe a 10 or 15w30.
    How old is the oil in there? A couple of months I guess. It shouldn't have deteriorated in that short space of time unless you are putting in massive mileages.
    Matt
    Aug 2012
    west bromwich
    no i hardly use it since it been done it only been used as a second car i do i find out if there a blockage
    Mar 2012
    liverpool
    16 Post(s)
    Trim : VXR
    Mileage : 44,000
    off topic but i love the vvt engine
    Feb 2012
    Calne UK
    You might want to try some flushing oil to get rid of a blockage.
    You run it through the engine, it breaks down the clumps of oil that clog up the system. You drain it out then refill with Castrol Magnatec, or something half decent.
    Also you might want to get the VVT Solenoids/Valves tested first though, these can cause a rattle or clatter on the top end new the timing belt cover.
    An Oil change on these is a very easy job and with practice can be done in a lunch hour easily.. It will give you an idea of the state of the engine...
    What colour is the oil now in there. If it's a couple of months old and it should be like new, or very slight discolouration.
    Matt
  1. 1.8vvt
    By platts007 in forum Engine & Drivetrain
    Last Post: 24th August 2011, 20:24
  2. Engine Management Light 1.8VVT
    By philroberts in forum Engine & Drivetrain
    Last Post: 16th August 2011, 21:21
  3. Anyone want to Colour Code 1.8VVT Engine?
    By mucklestone in forum Vectra C / Signum Car Chat
    Last Post: 4th December 2009, 16:08
  4. 25 mpg!!!!!! 1.8vvt sri
    By vectramad in forum Vectra C / Signum Car Chat
    Last Post: 17th September 2008, 07:45
  5. 1.8vvt
    By prm in forum Vectra C / Signum Car Chat
    Last Post: 27th December 2007, 11:54
