Thread: Rattle from back of engine?
    Jan 2012
    Milton keynes
    Trim : M Sport and Design
    Mileage : 38100
    Default Rattle from back of engine?
    (Z19DT 08MY)
    Developed a rattle recently, seems to be coming from the back of the engine, but I cant tell if its (hopefully) (just) the alternator or worse-case something to do with the timing belt area? (Belt/Pump replaced 10k ago)
    Its more obvious at idle, like the engine drops in power slightly, but as soon as you touch the gas pedal, it sort of disappears (probably behind engine noise) and becomes a slight vibration... that picks up with the revs.
    Now, I've JUST (less than 1k miles) had the clutch, flywheel slave cylinder blah blah replaced... could it be faulty??? When I let the clutch in, it rumbles and the engine becomes a fair bit louder.
    I also noticed that when I do press the gas, the lights dim slightly then pick up again, is that normal? (Battery replaced less than 100miles ago). At last check battery was 12.5v and just over 14v when running.
    What checks are there that I can do without taking the car apart to count things out? Check DMF, Alternator etc...
    Any other ideas what could cause a rubble/rattle in the engine bay? I've read about bottom end knocking, can I count that out?
    This car is starting to do my head in, went diesel to save money, I've spent loads more than I would have on my 2.0T even with the fuel costs so far!
    Jan 2012
    Milton keynes
    Mileage : 38100
    It also makes a knocking noise that's most evident when switching off...
    Jan 2012
    Milton keynes
    Mileage : 38100
    Any ideas?
    Jan 2012
    Milton keynes
    Mileage : 38100
    No one?
    Oct 2009
    Luton
    Sounds like the dmf mate
    South east
    DMF noise should be coming from the passenger side of the engine bay, rather than the rear.
    Jul 2011
    peterborough
    would of said dual mass flywheel but you say that been replaced, by yourself , did you see the old 1, or is it the alternator clutch ,
    Jan 2012
    Milton keynes
    Mileage : 38100
    The noise is more obvious from the passenger side when in the car and just sounds like the back of the engine from the engine bay. The clutch dmf etc was replaced by mr clutch so i never saw any of the old bits just the bill at the end! Lol
    Its going back on thursday to be looked at and hopefully i'll know one way or the other.
  1. Engine cover rattle and engine cough
    By Hursty103 in forum Engine & Drivetrain
    Last Post: 15th May 2012, 12:22
  2. Replies: 35
    Last Post: 5th May 2012, 15:32
  3. chain rattle back
    By bundy b in forum Engine & Drivetrain
    Last Post: 18th May 2009, 17:41
  4. Rattle from back brakes
    By Hesston in forum Suspension, Wheels & Brakes
    Last Post: 18th October 2006, 07:44
