Thread: 2008 vectra 1.8 sri trouble selecting gears, hard to get into gear but once in drives ok
    Jun 2012
    swadlincote
    Default 2008 vectra 1.8 sri trouble selecting gears, hard to get into gear but once in drives ok
    hi all i have a 2008/08 vectra c sri 1.8
    i drove it yesturday and it was fine but today the clutch peddle felt slack/lose but clutch working ok not slipping etc
    i carried on driving it today and all of a sudden it was very hard to select any gear i had to push the gear stick very hard to get into the gear i was selecting but once it was in the gear i selected it drove fine.
    i drove the car later on today after it had cooled down and it drove ok but then it did start to get alittle dodgy selecting gears again then it stopped and was fine again has anyone had this problem or know of anyone who has and know what it coloud be?
    thanks for your time
    Dec 2011
    Seaham
    Check the clutch fluid level?
    thats assuming its a hydraulic clutch.
    Jun 2012
    swadlincote
    the fluid is ok mate just checked it
    it is the same fluid bottle as the brake fluid isnt it?
    Dec 2011
    Seaham
    As far as I know it is. OK, then maybe you have fluid passing the seals, have you tried pumping the clutch pedal before shanging gear?
    Jun 2012
    swadlincote
    no mate
    Dec 2011
    Seaham
    I would try bleeding the the system, just incase you have air in it. It sounds to me the clutch isnt fully engaging when you press the pedal down.
    Jun 2012
    swadlincote
    how do you do that mate ? thanks for your advise
    Dec 2011
    Seaham
    There will be a bleed nipple on the slave cylinder, you bleed them like you bleed brakes.
  1. Problem selecting gears HELP PLEASE
    By vectra brian sri in forum Vectra C / Signum Car Chat
    Last Post: 2nd November 2012, 16:49
  2. Difficulty selecting gears 2.2 direct!!
    By platanayk in forum Engine & Drivetrain
    Last Post: 1st March 2011, 09:07
  3. Trouble selecting 1st gear
    By big nath in forum Engine & Drivetrain
    Last Post: 19th February 2009, 19:53
  4. External Hard Drives - Value For Capacity
    By Ben H in forum General Chat
    Last Post: 30th March 2007, 10:47
  5. Internal hard drives
    By big peachy in forum General items for sale
    Last Post: 17th March 2006, 20:00
vectra c hard to get into gear
hard to get gears on vectra c
vectra 1.8 hard to get gear
clutch oil bottle on a vectra
vectra c sri hard selecting gears
