Thread: help
    Jan 2008
    edinburgh
    Default help
    headlights come on as soon as turn ignition ,cant turn them off untill i turn ignition of.
    wirral
    36 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Needs turning via tech 2
    Seems like previous owner has set it up as drls
    Jan 2008
    edinburgh
    Default ???????????
    Quote Originally Posted by Critch View Post
    Wot does that mean
    Regular Member Chris B's Avatar
    Jan 2012
    Essex
    Tech 2 is the Gm/Saab diagnostic and option programming tool, usually only dealers and specialists have them.
    DRL is Daytime Running Lights - seems this is an option which can be set up using the Tech 2 device
    It might be worth checking the connector on the back of the headlight switch.
    IIRC, the headlights will come on if the switch is disconnected from its multiplug.
    To remove switch from dash, make sure in off position (or auto position if auto headlights) firmly push in rotary knob and while still holding in turn to the right. You should then be able to pull switch from the dash.
    Also, you might want to try the following.
    http://www.vectra-c.com/forum/showth...ave-you-hassle
