Results 1 to 2 of 2
Thread: egr valve leak
    northampton
    Default egr valve leak
    Happy new year!
    I had the EGR valve off yesterday as my car smokes after leaving it for 3 hours after a drive, but not when it is cold in the morning. I assume that the EGR valve should not leak any air into the intake manifold. The left hand valve (there are two) has a small air leak when i tested it.? It is only a small amount but none the less would the engine suffer due to a vacum leak? or something.....
    short answer, yes it would make a difference as it's letting in un-metered air into the engine.. however i would have thought that it would leak when cold as a bit of thermal expansion when it's hot should close a minor gap.. Chuck a new gasket under it, after seeing if the mating surfaces are flat and not damaged, and see if it runs better..
  1. Replies: 6
    Last Post: 29th July 2012, 13:52
  2. Oil leak 150 cdti oil leak help
    By sr_fly in forum Vectra C / Signum Car Chat
    Last Post: 14th July 2011, 20:46
  3. Egr valve, swirl valve problems etc..
  4. EGR valve and Intake air leak
    By iceeee in forum Vectra C / Signum Troubleshooting
    Last Post: 8th March 2010, 23:19
  5. Leak, front end creak, refurb, bent locking wheel key and another leak =(
    By nick-v2.2 in forum Vectra C / Signum Troubleshooting
    Last Post: 15th February 2010, 19:58
