Thread: Fuel Pump - Help Limp Home
    Regular Member JaceyBoy's Avatar
    Apr 2012
    Bournemouth
    Default Fuel Pump - Help Limp Home
    Guys,
    Just took off my fuel pump and stripped down to check it, put it back on the car and started it, the car went straight into limp home and wont rev above 3000rpm, whats going on?
    morecambe
    39 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Why have you took it apart Is the diaphram back in correct
    Apr 2012
    Bournemouth
    Looked fine to me, the top three bits on springs?
    Apr 2012
    Bournemouth
    Is there any guides I can follow on here to rebuild?, need to do ths before tomorrow as it needs to get me to work...
    Apr 2012
    Bournemouth
    Well ive done all I can, had it out stripped down 3 times and I cannot understand why it isnt working properly, as soon as you try and rev the car it goes into limp home mode....
  1. 2.2 direct limp home.....Fuel pump
    By scotty84 in forum Engine & Drivetrain
    Last Post: 10th October 2014, 18:26
  2. Limp Home
    By xf8u39 in forum Electrical & ICE (including SatNav)
    Last Post: 18th August 2012, 18:00
  3. egr blanked - 2000 miles and no limp home home
    By jonestown in forum Y & Z30DT Specific
    Last Post: 1st August 2012, 14:55
  4. dam limp home?
    By garry7000 in forum Engine & Drivetrain
    Last Post: 27th May 2010, 23:08
  5. Limp home mode and fuel pump
    By Netstar in forum Engine & Drivetrain
    Last Post: 2nd May 2007, 12:03
