Thread: bsr remap
    Regular Member dave786's Avatar
    Jan 2012
    leeds
    Default bsr remap
    hi will my mates bsr remap work on my veccy 2.0 turbo 57 plate
    Regular Member nikroc's Avatar
    Nov 2007
    DERBY
    13 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    Believe that each map is registered to one car only..you could allways try..dont know if youll do any irreprible damage if you do try tho
    South east
    It won't work unless you send the unit back to BSR and they upload a new map onto it, for which they're obviously going to charge you quite a lot. There won't be any damage from trying, it just won't load onto your car.
    Jan 2012
    leeds
    ok cheers didnt want to try incase it did damage to ecu
    morecambe
    35 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Won't work each car has a percifik check sum easy car to map though especially with it bein a trionic 8 ecu
    Full Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    I think it will lock down the bsr handheld ppc module if you try it. I tried to use my mqptun unit to read the cault codes from another car and it locked it down. Phone call and explanation later and they unlocked it.
    morecambe
    35 Post(s)
    Vehicle : vectra
    Trim : vxr
    As I said its down to check sums it pieces together if a piece is wrong it locks it
    Oct 2006
    Waterloo, Liverpool
    Trim : SRI NAV XP
    Engine : 1.9 CDTI 150
    Mileage : 72K
    Yep, as said, BSR remaps are not transferable to another car. Both my current and previous Vectra have been BSR-remapped.
  1. Replies: 15
    Last Post: 27th September 2013, 00:22
  2. 2.0t remap from remap science bradford
    By stefan7153 in forum Petrol Engine related
    Last Post: 4th May 2011, 22:03
  3. 2.2 dti remap
    By fattony in forum Diesel Engine related
    Last Post: 11th December 2008, 10:41
  4. 2.2 Remap
    By jaxouk in forum Vectra C / Signum Car Chat
    Last Post: 5th September 2008, 17:48
