Thread: Promotasport alloy coolant expansion tank
    Regular Member Kev_A's Avatar
    Gateshead, Tyne and wear
    Engine : Z20NET
    Default Promotasport alloy coolant expansion tank
    Bought this what seems like ages ago and had it sitting in the boot ever since.
    I was originally going to wait until I had a set of silicone coolant hoses, then I was going to drop the coolant, fit the new hoses and new tank at the same time.
    However, I didn't really fancy the X factor tonight so decided to go and fit it
    I didn't fancy dropping all of the coolant, instead I thought I'd try and drain the expansion tank and the top part of the bottom hose, not fancying a mouthful of coolant whilst starting a syphon, I fashioned a little device using a medium sized plastic syringe and a length of silicone vacuum tubing.
    I sat a plastic container under the engine, plugged the syringe into the tubing, fed it down through the 'bay then popped the cap off the expansion tank and fed in the tube, I then secured it so it didn't pop out mid-syphon.
    I then fully drew out the plunger on the syringe and quickly removed it and popped the end of the tubing into the container, instant syphon and no mess
    Once the expansion tank was drained I set about removing the 3 tubes and unplugging the level sensor from the old tank, it then simply lifts up and towards you, I propped the large bottom hose up as it was still full of coolant.
    Slotted the new shiny one in place (fits like a glove) and reconnected the hoses.
    Before...
    After...
    Only problem I've found is there's no hole for the coolant level sensor to plug into, I've emailed promotosport regarding this as when you can't see into the bottle you really do need some form of gauge there.
    I've turned the ignition key with the sensor unplugged and nothing shows up on the dash, no warning lights or images on the GID?
    I may just buy a gauge and use that instead if the car is happy enough with out it's sensor
    I'll grab some better pics in daylight tommorow
    Regular Member keith1983's Avatar
    Sheffield / Spalding
    Vehicle : Vectra 1.8 SRi
    Engine : Z18XE
    That looks great, are there any advantages other than aesthetics?
    Engine : Z20NET
    Don't think so mate, just aesthetics, gave it a clean and buff up this morning and it looks like a mirror now getting ready to go out now but will grab some pics later
    South east
    How do you check the coolant level?
    Engine : Z20NET
    You unscrew the cap and look into the tank
  1. expansion tank
    By Swedge in forum Engine & Drivetrain
    Last Post: 1st August 2012, 18:21
  2. Coolant Expansion Tank
    By Telboy in forum Engine & Drivetrain
    Last Post: 2nd May 2011, 21:11
  3. coolant bubbling from expansion tank 1.8LS 112k
    By TonyTangles in forum Vectra C / Signum Troubleshooting
    Last Post: 7th March 2011, 00:42
  4. expansion tank
    By signumturbo04 in forum Vectra C / Signum Car Chat
    Last Post: 13th June 2010, 21:25
  5. Expansion tank cap!
    By MadOnVaux! in forum Vectra C / Signum Car Chat
    Last Post: 20th March 2010, 17:51
