Thread: Bypassing coolant temp sensor?
    Aug 2012
    Bristol, UK
    Default Bypassing coolant temp sensor?
    I have a 2006 1.9cdti vectra that struggles with cold starts even on warm days. Changed the glow plugs and coolant sensor but that did not help at all.
    Yes there are lots of threads on this issue but i decided to create a new one as i have a specific question to ask (see Q2 below). I noticed that if the coolant sensor is disconnected, the car starts fine, however then there is the annoying light in the dashboard.
    I have two questions:
    1) could my problem be due to a faulty relay that has failed closed?
    2) is there a way to bypass the relay in a way that if I disconnect the coolant temp sensor or the sensor signal to the relay, the relay does not send the signal to the dashboard. Perhaps if someone can post the relay pin diagram. By relay I mean the glow plug relay. The aim is to ensure that glow plugs are utilised each time the car starts, hence the reason for disconnecting the temp sensor input. Could i simply cut off the output from relay to dashboard light?
    Thanks.
    VIP-Member
    Dec 2010
    London
    Engine : Z18XER
    Think you'll find the ECU puts dashlight on
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    They are ecu controlled.
    What are the coolant temp an intake temp readings?
    How long is glow light on for?
    Whats battery voltage? What's voltage at starter an current draw by starter?
    Mar 2012
    Dundee
    Vehicle : GSI
    Trim : (vxr/irmy)
    Engine : 3.2 v6
    Did you check your battery my battery was only 450 crank start where it should have been a 650 crank start in it soon as i put a new battery in it it fires up first go all the time
  1. coolant temp sensor
    By andy_richmond in forum Vectra C / Signum Troubleshooting
    Last Post: 1st October 2012, 23:18
  2. Coolant temp sensor
    By RBH in forum Vectra C / Signum Car Chat
    Last Post: 15th February 2012, 11:54
  3. coolant temp sensor
    By tomo610 in forum Vectra C / Signum Car Chat
    Last Post: 30th January 2012, 22:27
  4. coolant temp sensor help
    By mrdouglas in forum Vectra C / Signum Troubleshooting
    Last Post: 12th March 2011, 21:01
  5. coolant temp sensor
    By Morephun in forum Engine & Drivetrain
    Last Post: 15th September 2009, 02:27
coolant temp sensor vectra cdti
bypass coolant sensor vectra c
