Results 1 to 3 of 3
Thread: error code u2111
    Regular Member baz2003uk's Avatar
    Mar 2007
    swindon
    Default error code u2111
    just read the error code i am getting and its coming up with u2111
    Identifier: 0x0015
    VIN: W0L0ZCF6871032300
    Part Number:13204146
    Software version number: 12244872_
    Hardware key number: O100024518
    System description: DELPH0400
    Alpha code:
    Manufacturing date: 100116
    Code Index and version: 008 02
    Total number of fault codes: 1
    U2111 - CAN-Bus No Communication With EHPS (Electro-Hydaulic-Power-Steering)
    (00) - Present
    if i clear the code it comes back every time
    also i am only getting the car and spanner before start up as soon as engine is started off the light goes?
    anyone able to shed any light on this
    cheers
    Regular Member gixerjd's Avatar
    Dec 2011
    leeds
    Vehicle : vectra c
    Trim : vxr
    Engine : z28neh
    Mileage : 31000
    isnt there a problem with the connector on the abs pump that causes loads of problems with the steering as it all runs through it i herd it some where i could be wrong lol
    Nov 2012
    Cirencester
    I have the same problem pas not working completely would a dirty abs plug cause this?
  1. Error code reading and code readers
    By Ben50n in forum Engine & Drivetrain
    Last Post: 27th August 2012, 16:43
  2. error code
    By frag45 in forum Troubleshooting
    Last Post: 29th December 2010, 14:39
  3. error code
    By riauba in forum Vectra C / Signum Car Chat
    Last Post: 11th December 2010, 21:43
  4. Error code help
    By Cat_J in forum Troubleshooting
    Last Post: 18th January 2010, 17:48
opel u2111-c
u2111
Opel DTC U2111-00
u2111 vectra c
https:www.vectra-c.comforumshowthread.php171265-error-code-u2111
VAUXHALL U2111-C
code defaut u2111
vectra c u2111
opel vectra steering code u2111
u2111-00
2006 vauxhall vectra u2111
U2111 CODE
u2111 vectra
Vauxhall DTC U2111-7Fvectra c u2111 faultzafia fault u2111vauxhall fault code u2111OPEL U2111saturno code u2111 error u2111 opel vectravectra fault code u2111suzuki dtc u2111fehlercode u2111 symptom 7fvectra u2111 sortedvauxhall u2111-00
