Results 1 to 2 of 2
Thread: brake pedal problem
    Regular Member Swedge's Avatar
    Jul 2012
    Scottish borders
    Default brake pedal problem
    sometimes when i press the brakes it goes down then feels solid but the brakes arent fully on, then sometimes it will go fully down and brake properly
    any ideas? pads and disks look fine
    i do have an abs sensor away, could that be it? vectra 54 plate cdti
    11 Post(s)
    First thing, is the brake fluid reservoir full under the bonnet?
    Next thing is to bleed the brakes in case there is any air in the system and to also check for leaks.
    It could also be a brake servo problem. Is the pedal hard with the engine off?
    Initially it should feel the same as when the engine is running, but after a two or three pushes the pedal should harden up.
    Ultimately though you should refrain from driving the car until you've fixed the problem.
  2. For Sale: Vauxhall Insignia Brake Pedal Alloy Cover - SRI sports pedal cover
    Last Post: 20th December 2012, 21:36
  3. Brake pedal ?
    By Denbo in forum Vectra C / Signum Car Chat
    Last Post: 30th March 2011, 01:47
  4. brake pedal
    By barrie m in forum Suspension, Wheels & Brakes
    Last Post: 12th February 2010, 21:21
  5. 02 Vectra C 2.2 Dti- Brake Pedal Problem
    By Devildriver in forum Suspension, Wheels & Brakes
    Last Post: 3rd April 2009, 15:29
2014 vauxhall astra brake pedal problem
vectra c brake servo problems
