Thread: suspention help needed
    Jul 2012
    Warrington
    Default suspention help needed
    have baught a 2003 2.2dti ls and its been lowered and scrapes on everything and the inside of the rear tyres are chewed in only 2000 miles what i want to know is is the sri vec and the ls model differant ride hights as dont want to raise it to much just need it to be a bit raised or does any 1 know of a way to raise it cheers boys
    South east
    The SRi models ride 15mm lower than the non-sports models.
    Jul 2012
    Warrington
    is there any differance apart from springs then so i could put sri springs on my ls
    South east
    I think the SRi's have slightly stiffer shocks, but there's no harm in using SRi springs on your car - as long as they have the same axle weight rating as your car does. E.g., you can't use the springs from a Z20NET on a 1.9 diesel.
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    I have a full set of springs for ya car mate pop over if you want them I will even fit them
    Jul 2012
    Warrington
    how much
    May 2011
    bispham, blackpool
    are you sure its on lower springs and not coilovers jack the front up and have a look if their lowering spring with standard shocks then
    i have a set of gsi springs which are just the same as sri springs as in lowers by 15mm from standard which i will swap with you will only take us both a few hours to change them over. their in my garage off my car. i was going to buy some lowering springs in the next few week as i have coilovers on the car at the moment
    send a pm if intrested
    or if anyone else has 40mm or 45mm lowering springs i have a set of ta-technix coilovers in exchange
  1. New suspention fitted to the GSI
    By Bloicy in forum Styling
    Last Post: 20th March 2012, 14:02
  2. Recommend me new suspention set-up
    By Bloicy in forum Suspension, Wheels & Brakes
    Last Post: 21st February 2012, 00:33
  3. suspention problems
    By JonesG in forum Vectra C / Signum Car Chat
    Last Post: 6th April 2011, 05:01
  4. new suspention
    By *enery* in forum Vectra C / Signum Car Chat
    Last Post: 11th January 2011, 11:43
  5. suspention noises
    By johnturbo in forum Suspension, Wheels & Brakes
    Last Post: 16th January 2010, 10:13
