Thread: Brake caliper slider bolts
    Aug 2012
    basingstoke
    Default Brake caliper slider bolts
    Are the caliper slider bolts the 7mm allen key ones?
    Ive ben advised they should be kepted greased to avoid seazing and brakes binding.
    scotland
    yes they are 7mm make sure the rubber is clean an a slight amount of copper slip on the body not the threads will be fine
    Aug 2012
    basingstoke
    Thanks mate
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    And if the rears you're doing remove the rubber that the slides sit in and clean any corrosion out. The calipers corrode which swells the rubber around the slides
    Nov 2009
    newcastle
    There's a vx kit to redo the sliders. Not sure of part number tho.
    Def get them greased. Both mine seized. Got told as pads and discs were both running low, sliders fully extended and much more Lilly to happen.
    New calipers done now
    11 Post(s)
    Quote Originally Posted by gsxrster View Post
    White lithium grease, marine grease or red rubber grease is better than using copper slip.
    IIRC Vx recommend that lithium grease is used.
  1. Caliper bolts....
    By dilan in forum Vectra C / Signum Car Chat
    Last Post: 24th October 2012, 12:02
  2. Caliper carrier bolts - still can't get them
    By shchuka in forum Vectra C / Signum Car Chat
    Last Post: 2nd October 2012, 14:45
  3. Where to get caliper carrier bolts?
    By shchuka in forum Suspension, Wheels & Brakes
    Last Post: 23rd September 2012, 22:01
  4. Caliper mounting bolts
    By Readster in forum Vectra C / Signum Car Chat
    Last Post: 12th May 2009, 19:09
  5. Replacing Brake Discs - new caliper carrier bolts?
    By markconlen in forum Suspension, Wheels & Brakes
    Last Post: 2nd January 2008, 23:32
