Thread: What happens if I just unplug a suspect bad EGR on a 1.9CDTI 150?
    Redcar
    Default What happens if I just unplug a suspect bad EGR on a 1.9CDTI 150?
    If I unplug it, is that the same as blanking or will this cause serious issues? Thanks
    Full Member Lao's Avatar
    Aug 2009
    Romania, E.U.
    Vehicle : Vectra C Estate Automatic
    Trim : Elegance
    I'm running with it unplugged for 2 years now. Car runs very nice. Only downside is the EML light will be ON all the time.
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Will put management light on.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Will put EML light on and itself may not 'seal' properly compared to a blanking plate. I've had mine blanked off for 23k now, no issues and it has been mapped off of the car now for the last 10k - means there is no EML light and the EGR valve is fully sealed.
    Regular Member Craig1985's Avatar
    harwich essex
    Thinking of unplugging mine to bring light up and plug it back in and get dealer to replace it under warranty. Easy way to rule out my lack of power ;0/
    Mar 2012
    wakefield
    Vehicle : vectra v6 cdti
    Trim : sri
    Mileage : 70000
    Im sure i've read somewhere if its got a dpf that part can be damaged,only on estates and signums.
    Regular Member Keif's Avatar
    In the Garage
    Quote Originally Posted by Lao View Post
    So if you have another engine issue you won't know, as you'll assume it's only showing the EGR is unplugged!
    Aug 2009
    Romania, E.U.
    Trim : Elegance
    Exactly.
  1. Unplug EGR: Top one or bottom one or both
    By mtqn in forum Diesel Engine related
    Last Post: 8th August 2012, 22:36
  2. How do u unplug Door switch Connector ???
    By Dal5band in forum Bodywork & Interior
    Last Post: 28th March 2012, 23:19
  3. How do you unplug heater control panel ?
    Last Post: 30th January 2012, 23:14
  4. cant unplug my temp sensor on my thermostat
    By justin32 in forum Engine & Drivetrain
    Last Post: 10th December 2011, 16:16
  5. unplug air flow meter
    By monkeyoodle in forum Engine & Drivetrain
    Last Post: 15th February 2011, 06:59
vectra c 1.9 unplug egr
https:www.vectra-c.comforumshowthread.php171238-What-happens-if-I-just-unplug-a-suspect-bad-EGR-on-a-1-9CDTI-150
unplugging egr on 1.9cdti vectra
1.9 cdti egr valve unplugged
what happens when you unplug the egr valve on a vectra c
what happens if you unplug the egr valve
what happens if i unplug the egr valve
vectra cdti egr valve unplugging
unplug egr valve vauxhall
