Thread: Done Timing Belt 19 cti now engine light on?
    Carnoustie
    Default Done Timing Belt 19 cti now engine light on?
    Done my timing belt today as per the excellent how to, also water pump, all went well, I started it up with the air box still removed, it started ok but engine light came on? put it down to missing airbox so re fitted it but light is still on? anyone know what the problem might be? this will bug me overnight! too dark now to mess with it!
    thanks for any advice
    Ronnie
    Regular Member vmb2722's Avatar
    May 2012
    Blackpool/St Mary's Bay
    5 Post(s)
    Trim : Exclusiv
    Engine : 1.9 CDTi 150
    did you reconnect the MAF?
    wirral
    36 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Was the MAF also unplugged?
    Try disconnecting battery for 15 mins
    Carnoustie
    Quote Originally Posted by vmb2722 View Post
    Yes made sure that was on, nothing else was unplugged so it seems strange?
    thanks Ronnie
    Carnoustie
    Quote Originally Posted by Critch View Post
    cheers will go that a try in the morning
    Carnoustie
    All fixed now, was staying on due to the airbox being off, had to reset the fault code
    cheers Ronnie
  1. anyway to do the timing belt without timing tool
    Last Post: 15th December 2012, 18:47
  2. Timing belt failure/knackered engine???
    By 123rado in forum Engine & Drivetrain
    Last Post: 15th December 2012, 18:35
  3. Engine noise louder than it was before timing belt was replaced
    By the-converter in forum Engine & Drivetrain
    Last Post: 14th October 2011, 12:26
  4. Timing belt.. 1.8 petrol engine
    By waterbourne in forum Vectra C / Signum Car Chat
    Last Post: 10th May 2011, 21:05
  5. timing belt kit
    By Rapala in forum Vectra C / Signum Car Chat
    Last Post: 28th December 2008, 15:09
