Likes Likes:  2
Thread: Alternator pulley - replacement has finally arrived
    Jun 2009
    South Coast
    8 Post(s)
    Vehicle : Signum & Insignia
    Engine : POS derv
    Question Alternator pulley - replacement has finally arrived
    It has taken two weeks but for the price i paid it was worth the wait..
    My engine started the annoying squeak that does not fully go away even after the engine has warmed up.. I know its not the belt or tensioners as I replaced them not so long ago. A dab of wd40 on the pulley spindle makes it a little more bearable..
    So with the arrival of the replacement uprated Bosch pulley i am itching to change it but having not done one before I am curious if its a home job or if a need a special tool to remove the pulley from the alternator.
    Does anybody have any experience of this job?
    South east
    You need a puller - available anywhere, but you need to get the correct size. Something like this in principle, but size dependent:
    http://www.ebay.co.uk/itm/DRAPER-6-S...item1e719e5112
    How much did the pulley cost you BTW?
    Jun 2009
    South Coast
    8 Post(s)
    Engine : POS derv
    ah cool, i have a set of those gear pullers...
    It cost me about £80 delivered for the new Bosch uprated pulley. The dealers wanted about £260 for the part..
    South east
    I might be wrong about the puller - not sure, but I "think" it's only needed for the internal bearing (the ones for the shaft that goes through the alternator), it's possible the one you want to swap can just be unscrewed; but if it doesn't come off then at least you have the puller to hand.
    Jun 2009
    South Coast
    8 Post(s)
    Engine : POS derv
    i understand what your saying.. the pulley has about 6mm of splines on the inside on the alternator side (hope that makes sense) so that may mean having to use a puller to release it.. I will update either way once the job is done tomorrow.
    South east
    Just had a read of some technical docs, it says the pulley has an anti-clockwise thread on it - you can probably confirm that from your replacement part.
    Jun 2009
    South Coast
    8 Post(s)
    Engine : POS derv
    Quote Originally Posted by Rebellion View Post
    That is correct...
    my concern is, undoing the retaining bolt but not turning the shaft, i am thinking its best to loosen it with the belt still on it and once replaced to tighten it when back on the shaft and the belt back on.
    Engine : 1.9 CDTi
    Shame I am away at the moment as I have access to the tools that are needed on some of them.
    If you get stuck and can wait I can get them and we can do out next weekend.
    Jun 2009
    South Coast
    8 Post(s)
    Engine : POS derv
    well what a load of hassle that was.. i wanted to change it with the alternator still on the car but that turned out to not be possible. they are defo not the easiest of things to remove from an engine bay but i managed it only to find that the coolant pipe to my turbo was perished..
    Fitting the new pulley to the alternator was a *****, i ended up taking a drive in the wife's car to go and find a workshop that was open that might have a spline tool to fit the new pulley.. I eventually found a place who did it for free but i gave them a drink anyway for the job considering what it has saved me... Then it was off to find a new coolant pipe, my local chandlers came up trumps with a pipe more than fit for purpose as usual.
    In the end and despite all the fannying about its done but has left with me with another job for next weekend... its never ending with these vauxhalls but we know that..
  10. Likes Dog_Book liked this post
  11. #10
    Mar 2017
    Northern Ireland
    Trim : SRi XP
    Engine : CDTi 150
    Quote Originally Posted by Caveman_nige View Post
    Would it have made a noise like this mate?
  1. alternator clutch pulley
    By SWEED in forum Engine & Drivetrain
    Last Post: 1st July 2010, 13:34
  2. Alternator rattle - new clutch pulley 93182514?
    By charlie in forum Engine & Drivetrain
    Last Post: 28th April 2009, 17:43
  3. alternator pulley squeak.
    By kev bux in forum Engine & Drivetrain
    Last Post: 10th May 2008, 14:28
  4. replacement vxr skirts arrived finally.
    By kev bux in forum Vectra C / Signum Car Chat
    Last Post: 13th September 2007, 16:39
vectra c alternator pulley cost
change alternator pulley vectra c
z20net alternator pulley replacement
vectra cdti 150 alternator pulley
replace alternayor pulley vectra
vectra 19cdti alternator
vectra alternator pully removal
2007 opel astra cdti alternator pulley change
vectra c alternator pulley replacement
vectra c alternator bearing
astra 2007 alternator pulley
difference in vectra c clutch pulleys
vectra cdti alternator pulley removal
vauxhall signum cdti 150 alternator clutch
vectra c alternator pulley removal
vectra c alternator removal
vauxhall vectra c 1.9 cdti alternator pulley socket
vectra c 1.9cdti alternator clutch pully
z19dth squeaky engine
https:www.vectra-c.comforumshowthread.php171224-Alternator-pulley-replacement-has-finally-arrived
vectra c alternator replacement cost
vectra c 1.9 alternator pulley collapsed
vectra 1.9cdti alternator pulley
how do i change a alternator pulley on vectra
