Results 1 to 10 of 13
Thread: 1.9 CDTI 150 glow plugs - DIY or garage?
    Feb 2009
    Ingleby Barwick
    Default 1.9 CDTI 150 glow plugs - DIY or garage?
    I have one knackered glow plug to change. I know I could spray it with penetrating oil (PB Blaster I use), leave it for ages, heat the engine up and try to remove it myself very carefully. Could be a really easy job, but could be a disaster if after taking these steps it shears and gets stuck or the tip falls off.
    The question is, does anyone know any garages in the Teesside area that are really skilled in removing them, or are known to have specialist equipment to minimise the risk of them breaking? If there are then for the sake of a few quid it might be worth me leaving it to the experts just to avoid the risk.
    Oct 2008
    Trim : leather
    Engine : 2.2 d
    Year : 2013
    I changed all four on my Vec cdti 150 when I had it, all four came out easy enough with no problems. I really thought it was just the older 2.0/2.2DTi engines that gave problems with the glow plugs stripping threads or breaking. Maybe I was just lucky.
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 85000
    Start spraying wd40 on them now, and do it every day for at least a week, even if you dont plan on swapping them yourself, they are notoriously tricky to remove in one piece.
    Jun 2006
    Lake District
    Vehicle : Vauxhall Insignia
    Engine : CDTi 160
    Mileage : 53.000
    Use 'PlusGas' as it's a dedicated penetrating fluid rather than a multi-purpose spray....its ****** great stuff
    Nov 2009
    newcastle
    I'd do myself on a 150 engine but not a 120(like mine) due to ease of getting to them. Just get some proper penetrating spray as wd40 does a job but others better at this.
    Regular Member bigdave1701's Avatar
    York
    I just give em a blast of WD40, go make a brew, come back and take em out. Done em twice on my 150 cdti and once on my old dti without issue. Trick is to give em a slight tweak in the opposite direction to break the crust (as though you're tightening em) before undoing em.
    Regular Member Barlow's Avatar
    Jan 2012
    Chester
    Vehicle : Nissan 350Z GT
    Engine : 3.5 V6
    Year : 06
    Mileage : 50,000
    Quote Originally Posted by geordieric View Post
    This.
    150 easy. 120 pig
    Regular Member lofty's Avatar
    Sep 2007
    @home
    Vehicle : Vectra C Estate
    Engine : 1.9 CDTi
    Went to change mine the other day.. the couple I tried undid easy enough but they didn't want to come out so I tightened them back up. The engine wasn't really warm at the time so I might try again when it's at temp.
    Feb 2009
    Ingleby Barwick
    Thanks very much for all the replies. I think I might give it a go myself
    Sep 2007
    West
    I've always done my own, Astra 1.7 dti (isuzu lump) Zaffy dti, Vectra B 2.2dti, Vecta C 2.0dti, Vectra C cdti 16v... a squirt of wd40 & a run round the block prior always does the trick.
  1. 1.9 CDTI 150 Glow plugs....Help???
    By bogjust in forum Engine & Drivetrain
    Last Post: 28th January 2013, 12:20
  2. 1.9 cdti 120 glow plugs
    By big rich in forum Engine & Drivetrain
    Last Post: 10th September 2010, 13:46
  3. 1.9 cdti 120 problems EGR/DMF/Glow Plugs
    By richy54321 in forum Engine & Drivetrain
    Last Post: 4th June 2010, 23:12
  4. Glow plugs on a CDTI 120
    By sthomson1 in forum Engine & Drivetrain
    Last Post: 5th November 2009, 22:39
  5. Glow plugs 1.9 cdti 120
    By mark230678 in forum Parts for sale
    Last Post: 3rd July 2009, 21:40
best glow plugs astra 1.9cdti mk5
how to change glow plugs on a vauxhall vectra cdti
vectra glow plug stuck
changing glow plugs vectra 2007
vectra c glow plug removal
how to change glow plugs on vauxhall zafira 1.9 cdti
2007 astra 1.9 cdti glow plug change tools needed
replacing signum glow plugs
vectra c 2.0 diesel glow plug change tools needed
vectra cdti 150 bosch glow plugs
2008 vectra 1.9 16v replace glow plug
vectra 1.9 cdti glow plug
vauxhall glow plug removal tool
how to test glowplugs on vectra c
glow plug diy 1.9cdti
vectra 1.9cdti glow plug torque
how to change glow plugs on zafira 1.9cdti
vectra c 150 glow plugs removal
vectra c 150 glow plug removal
astra 1.9 cdti performance glow plugs
how to start vectra with knackered glow
best glow plugs for vauxhall astra 1.9 cdti
changing vectra c glow plugs
vectra c best glow plugs
where are glow plugs located on vectra 1.9 cdti
