Results 1 to 10 of 13
Thread: Coil Pack? HELP!!
    Regular Member JaceyBoy's Avatar
    Apr 2012
    Bournemouth
    Default Coil Pack? HELP!!
    Guys, I have a 2004/54 2.2i Signum, I get a cut of power out around 3,000rpm and above then its fine, but sends the spanner light on until I turn off ignition and then on again, I have changed the plugs (which made it better) but it still does it, I am frightened to overtake anyone as I always cuts, would this be a coil pack fault or the dreaded fuel pump?, before I changed the plugs a friend plugged in the diagnostics and it came up with cylinder 1 failure....
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Fuel pump or the fuel pressure regulator mate
    Apr 2012
    Bournemouth
    How much is the fuel pressure regulator to replace?
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    There about 60-75 on eBay Maye waste of time tbh I can probably assure you it's the fuel pump
    Apr 2012
    Bournemouth
    How I can find out for sure?
    Jun 2009
    South Coast
    6 Post(s)
    Vehicle : Vectra, Signum & Insignia
    Engine : Z18XE,Z19DTH,Z20NET,
    can you read off the fault codes?
    The wifes vec show car is currently being stripped for parts before i scrap it, keep an eye on the sales section.. https://www.vectra-c.com/forum/garage_vehicle.php?do=view_vehicle&id=709
    Apr 2012
    Bournemouth
    The only fault code I have managed to get from it is Cylinder 1 failure
    Apr 2012
    Bournemouth
    Any other help with regards to how I can diagnose this fault?
    Jun 2009
    South Coast
    6 Post(s)
    Your engine is different to mine,, but not by too much, that code would mean to me that a coil has had it.. If the coils are individual like mine then you can swap them round (i.e. 1 and 4), try this to see if the misfire moves to cylinder 4. Its something you can try for free and its easy to do.
    Apr 2012
    Bournemouth
    My coil pack is in a line of 4 and sealed..
  1. Another Coil Pack!
    By mat_splat in forum South Central (ARO - matty2fatty)
    Last Post: 16th November 2012, 23:54
  2. Think it needs a coil pack ?
    By simac in forum Engine & Drivetrain
    Last Post: 11th February 2011, 19:58
  3. coil pack
    By dezwez in forum Vectra C / Signum Car Chat
    Last Post: 30th May 2010, 19:41
  4. coil pack
    By cdms811 in forum Vectra C / Signum Car Chat
    Last Post: 15th February 2009, 00:28
