Results 1 to 7 of 7
Thread: Warm aircon
    Dec 2010
    Teesside
    Cool Warm aircon
    The aircon on my vectra is no cooler than just using the ventilation, also when its on I can't hear the pump start or anything, the button lights up but nothing happens.
    I know aircon needs regassing after so long, but would that cause it to do nothing or just to run warm?
    Its only 4 years old with 50k miles, should it run out that soon?
    Planning a 300 mile trip to dorset next week so preying for cool weather lol
    Oxfordshire
    13 Post(s)
    Vehicle : Vauxhall Astra-J
    Engine : 2.0 CDTi
    Year : 2013
    If the AC system is low, then the compressor won't engage to prevent damage.
    As to running out 'so soon'. Maybe the system has a leak. Condenser damage by a stone, or through lack of use in the winter for instance which let the rubber seals dry out?
    Regular Member MattVecVXR's Avatar
    Mar 2012
    Torpoint, Cornwall
    Trim : VXR
    Engine : 2.8 V6 Turbo (280)
    Mileage : 82000
    Exactly as Big Dave said, I'm in the same position and not looking forward to the potential costly repair for something I'll barely use for the next 8 months.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    You should use your aircon during the winter as it helps clear the screen quicker. Its not just for summer!
    Oxfordshire
    13 Post(s)
    Engine : 2.0 CDTi
    Year : 2013
    Quote Originally Posted by merikiito View Post
    Used in conjunction with the heater, it is just the same as climate control, although slightly more primative as you have to manually control things instead of the CC doing it for you.
    Dec 2010
    Teesside
    I always use the aircon in winter, warms the car up quicker and demists better, guessing the last owner didn't, as I got the car in march, I can probably live without ac if the repair bill is a big one
    Mar 2012
    Torpoint, Cornwall
    Trim : VXR
    Mileage : 82000
    I don't use it for demisting because I use Rain-x anti mist on my windows so never had to. I have always run the aircon in the winter for about an hour a week to prevent MBG in the system and to keep the seals wet, but I've only had the car since March and lost the whole charge the week the warranty ran out.
  1. Aircon problems - Not working, if anything air gets hotter turning on aircon???
    By Coupe2T in forum Electrical & ICE (including SatNav)
    Last Post: 30th July 2012, 10:13
  2. to warm
    By graham a in forum The 'Off Topic' room
    Last Post: 28th June 2011, 20:33
  3. warm aircon
    By Big Knox in forum Vectra C / Signum Car Chat
    Last Post: 3rd June 2011, 06:51
  4. A bit warm
    By MattW in forum The 'Off Topic' room
    Last Post: 25th July 2008, 21:12
  5. Change aircon to auto-aircon?
    By um20 in forum Electrical & ICE (including SatNav)
    Last Post: 20th March 2007, 22:12
