Thread: Lower headlining without creasing?
    May 2012
    UK
    Default Lower headlining without creasing?
    Hi all
    This is following on from another post regarding my roof aerial being broken off I have a question about removing the headlining that may be missed in that post but I need some advice on - so sorry mods for making another thread!
    I need to lower the headlining to access the aerial base (my car is a facelift hatchback), I found the 'how 2' guide and have started to pull down the headlining (I removed the rear grab handles) but it seems to crease very very easily so I am scared to remove any more. I would need to pull it a fair way down to gain access easily to the base of the antenna.
    Is there a way to prevent it creasing while being lowered to access the aerial?
    Any advice would be appreciated!
    Admin plasma's Avatar
    On the Forum
    185 Post(s)
    Engine : 150
    Mileage : 74000
    remove more trim, ie the c-pillar and if need be the b-pillar trim. the roof lining is very forgiving and the creases do disappear when put back.
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
    May 2012
    UK
    Quote Originally Posted by plasma View Post
    Thanks, do you have any tips on how to remove the pillar trims? esp the B with it having the airbag!
    On the Forum
    185 Post(s)
    Engine : 150
    Mileage : 74000
    The bit that says Airbag isnt... thats just a clip you pull out.... The side airbag is a long rod which starts from the rear of the car across the top to the front A-pillar its similiar to a curtain rod, thus called curtain airbag
    May 2012
    UK
    Ah ok I see, would you have any instructions to remove the C & B pillar trims or can you point me to a thread that has it, I've been looking but can't find anything so far!
    Thanks!
    May 2012
    UK
    Sorry for the bump but if anyone has any insight into removing the pillar trims (esp B & C) it would be v helpful! I'm taking a look at the car later today
  1. Headlining
    By leeds vectra in forum Detailing and Car Care Discussion
    Last Post: 16th March 2012, 02:34
  2. headlining
    By fiend61 in forum Bodywork & Interior
    Last Post: 15th December 2011, 00:01
  3. Headlining
    By spennny in forum Detailing and Car Care Discussion
    Last Post: 19th July 2011, 21:04
  4. headlining removal!
    By mann3210 in forum Vectra C / Signum Car Chat
    Last Post: 2nd May 2011, 12:25
  5. How do you lower the front of the headlining?
    By rushy in forum Bodywork & Interior
    Last Post: 26th March 2011, 12:08
