Thread: Clunking over bumps
    Jun 2009
    Nottingham
    Default Clunking over bumps
    I'm convinced that the state of the roads is giving suspension and associated parts a hard time. Hhad new front springs a couple of years ago. Ther's an annoying knocking noise going over bumps. What parts are likely to be worn and approx. how much to replace?
    Andy
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Drop links
    About 30 quid for the pair
    Regular Member bigdunk1985's Avatar
    Aug 2011
    Ellesmere Port, Cheshire
    Trim : GSI
    Year : 2002
    cheers, saves me asking the same question. got the same problem on the front
    Jun 2009
    Nottingham
    Doesn't sound too pricey. Do they take long to fit? Just wondering what an independant garage might charge.
    Also sounds a bit of knocking from the rear. What might this be?
    Andy
    Jan 2012
    Milton keynes
    Trim : M Sport and Design
    Mileage : 38100
    Have you checked that the springs havent gone again, or the shocks? Do you have the rubber sleeves on the bottom of the front coils?
    Rears, again springs, shocks, warn ARB bush and probably control arms I think can cause knocking...
    Changing droplinks is easy, 10-15 minutes maybe each. Wheel off, support the shock with a 2nd jack under the hub carrier and raise / compress slightly to remove weight from top mount, undo the top mount (use a spanner at the rear and socket for the front) then do the bottom same way...
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Providing the bits come of easy enough then only a few mins per side.
    Knocking at rear could be the same but may also be upper control arms
    Full Member RBH's Avatar
    Jan 2008
    North Lanarkshire
    88 Post(s)
    Vehicle : INSIGNIA
    Trim : VX LINE
    Engine : 2.0 CDTI
    Mileage : 44000
    get the uprated saab droplinks
    around £40 for the pair. u wont be disappointed with them.
    Jun 2011
    brum
    I've got the same on drivers side, changed drop links and arb bushes and not fixed yet. Only happens when going over sharp bumps such an badly worn roads and pot holes, can go over speed bumps without it knocking though. So I've got to start looking at other bits. I thought the top mounts but supposedly they will knock whenever the suspension compresses and not just when it is "shocked" going over a pothole
  1. rattling from rear end over bumps
    By tomo41 in forum Vectra C / Signum Car Chat
    Last Post: 17th August 2011, 00:03
  2. Squeek over bumps
    By blackveccyC in forum Suspension, Wheels & Brakes
    Last Post: 28th July 2011, 21:16
  3. Soddin Speed Bumps....
    By macdad in forum General Chat
    Last Post: 17th July 2009, 21:46
  4. rattle over bumps
    By dannydm1 in forum Suspension, Wheels & Brakes
    Last Post: 11th November 2008, 20:03
  5. Speed Bumps
    By suj786 in forum General Chat
    Last Post: 6th January 2008, 08:03
vectra c rattle over bumps
vectra c clunking over bumpsclunking over bumps vauxhall vectra
