Thread: Roof Spoiler Estate
    Regular Member johp778's Avatar
    Apr 2012
    Leeds, W Yorks
    Default Roof Spoiler Estate
    Hi All
    Received my spoiler from eBay, it's fibre glass, but the body shop I've asked to paint it say there's a possibility it might bubble over time from the chemicals bleeding through and a GENUINE spoiler would have been the recommended option (bodyshop is an independent).
    Has anyone had any issues with none vaux/irmscher spoilers?
    Slough
    91 Post(s)
    Vehicle : insignia vxr
    Trim : vxr
    Engine : 2.8 turbo
    Year : 61
    Mileage : 38000
    Quote Originally Posted by johp778 View Post
    Hi All
    do know off anyone that has had problems with them . ive a copy boot spoiler and in over 2 years not had a problem with it . just get the prep right and top coat job done .
    the vectra has gone , but not far away so ill still see it form time to time
    Apr 2012
    Leeds, W Yorks
    What prep did you do? As far as I've been told, make sure roof is clean and dry and to make sure there's no oils use petrol to wipe it over, then simply apply glue to edge of spoiler and then i'll get someone to help put in place.
    Bodyshop said it will be better to let the paint air dry slowly, rather than in oven, so i've left it with them to do and see what it looks like when done. I'm hoping it will be ok, or as they said it will have been a false economy buying cheaper non-gen.
    Slough
    91 Post(s)
    Trim : vxr
    Engine : 2.8 turbo
    Year : 61
    Mileage : 38000
    not got the roof one , but the other 2 are only copies and were done in the bodyshop with no problems , there are a few members that have painted and then stuck them on ,.
    WGAF#5
    I would imagine if it's going to react it wold do so when painted ... Straightaway and not over time... I've seen this occur on cheaper spoilers and it was pretty much instantaneous once cured/dried
    So get them to paint it ... If it blisters and bubbled then there is an issue ... There just telling you so that IF it does ( I'm not saying it will) then they will still expect you to pay for their time and materials
    Apr 2012
    Leeds, W Yorks
    It's actually the bodyshop that does all or cars we send from work, so he's only charging me £100 to do spoiler, grille and a mirror cover, but he just said it can happen even after a year or so in the sun, but I also assumed it would happen straight away if it was going to
    Regular Member Daywalker's Avatar
    Aug 2007
    Kaunas raj
    Vehicle : Qashqai
    Trim : Visia
    Engine : 1.5dci
    Year : 2010
    I had a copy roof spoiler on my signum and never had a problem at all, as Khalid said just needs to be prepped and sprayed properly
  1. Rear Roof Spoiler Estate
    By johp778 in forum Styling
    Last Post: 8th August 2012, 13:57
  2. Estate roof spoiler idea
    By Rob12 in forum Styling
    Last Post: 30th May 2012, 20:56
  3. Vectra estate Roof Spoiler
    By tonyt in forum General Chat
    Last Post: 12th March 2007, 22:32
