Results 1 to 3 of 3
Thread: Another Cruise control question!
    Dec 2011
    Larkfield
    confused Another Cruise control question!
    I had problems with my cruise control, i think the only thing i haven't done is change the clutch spring however had to take the battery out, after that i had problems with my alarm not working properly.
    When i plugged it into my computer it came up with "curcuit open" for both the cruise control and the alarm which it never had before.
    Ive checked fuses etc and all appear to be ok (not that i can find one for CC)
    Any idea's or will i be taking it down to Vauxhall to get screwed over?
    Full Member spennny's Avatar
    Blantyre
    Open circuit means that there is a contact missing each other , i would bet it the connection where the end of the stalk connects inside the CIM,
    Mine was the same , i removed the stalk and carefully raised the flat connectors slightly with a paper clip o and also wrapped some celotape round the bottom of my stalk
    Ireland
    I had a lot of intermittent problems with the cruise control stalk contacts, would drop out of cruise whenever I lane changed or went over a bump.
    I cleaned everything really well, even disassembled the CIM & cleaned some black stuff on the sliding switch conatcts.
    This made it work for a few weeks, then gradually started seeing the intermittent problems again.
    Tried using wd40 & also electrical switch cleaner, was only a temporary fix.
    I used Lithium grease on the stalk contacts & it's worked great since, no problems for over 6 months now.
  1. cruise control question
    By glens14a in forum Vectra C / Signum Car Chat
    Last Post: 25th July 2010, 09:07
  2. cruise control
    By stuart bigboy in forum Electrical & ICE (including SatNav)
    Last Post: 15th August 2008, 23:27
  3. Standard CD player and cruise control question
    By freshprince in forum Electrical & ICE (including SatNav)
    Last Post: 3rd July 2008, 20:58
  4. Cruise Control
    By bigcarman79 in forum Electrical & ICE (including SatNav)
    Last Post: 28th April 2008, 20:33
  5. manual control or cruise control.
    By johnm in forum Vectra C / Signum Car Chat
    Last Post: 6th February 2008, 14:20
