Thread: Cold start issue - Thread 1,426
    Regular Member Barlow's Avatar
    Jan 2012
    Chester
    Vehicle : Nissan 350Z GT
    Engine : 3.5 V6
    Year : 06
    Mileage : 50,000
    Default Cold start issue - Thread 1,426
    Ok, a lot of us have this issue and none has found a fix.
    The obvious fix is to force the plugs to stay on for longer, and disconnecting the coolant sender plug does this, albeit it keeps the fan on :/
    Now does anybody have any knowledge of electronics?
    I'm thinking if an inline resistor is soldered into the plug wire that it would fool the ECU into thinking the engine is colder than it is and keep the plugs on longer?
    Thoughts?
    Regular Member Sebastian's Avatar
    Electric Heated Recaro Leather
    36 Post(s)
    Engine : 1.9 DTH
    Change starter motor iirc ??
    Jan 2012
    Chester
    Engine : 3.5 V6
    Year : 06
    Mileage : 50,000
    Done
    Mar 2012
    Dundee
    Vehicle : GSI
    Trim : (vxr/irmy)
    Engine : 3.2 v6
    I fixed mine i got a new battery and it fixed it lol
    Jan 2012
    Chester
    Engine : 3.5 V6
    Year : 06
    Mileage : 50,000
    Done that too lol
    And leak offs, thermostat, glow plugs, GP relay.
    Only option I can see is to hack the glow plug glow time
    Mar 2012
    Dundee
    Vehicle : GSI
    Trim : (vxr/irmy)
    Engine : 3.2 v6
    I'm glad i got mine sorted for winter coming in all i need to worry about now is when it snows i will struggle to get u my hill lol
    Nov 2010
    East Midlands
    Trim : design
    Glad your sorted - are you sure it was the battery or could it have been the starter motor
    Jan 2010
    Trim : 1.9 cdti
    Engine : 120
    Year : 06
    Quote Originally Posted by Barlow View Post
    Done that too lol
    Have you checked the injectors/copper washers? Do you park your car uphill? If you do, try to park downhill and check if same problem still persists.
    May 2011
    Ashby-de-la-Zouch
    Trim : sri nav/Elite
    Engine : CDTI 150
    Year : 56
    Mileage : 130ish
    have you change the cam and crank shaft sensor that worked for me. i think it was the cam mainly.
    Mar 2012
    Dundee
    Vehicle : GSI
    Trim : (vxr/irmy)
    Engine : 3.2 v6
    Quote Originally Posted by alcutler View Post
    Na it was deffo the battery was still the same after i changed the glow plugs/glow plugs rally and the starter.
  1. z18xe Idle issue on cold start up
    By danno in forum Engine & Drivetrain
    Last Post: 9th March 2013, 19:40
  2. smoke at cold cold start
    By azacbr6 in forum Engine & Drivetrain
    Last Post: 5th December 2012, 18:23
  3. vetra 1.9 cdti cold start issue
    By all vaux in forum Engine & Drivetrain
    Last Post: 21st December 2011, 20:33
  4. DTi starting issue when warm (not hot or cold)
    By James24 in forum Engine & Drivetrain
    Last Post: 11th December 2010, 20:28
  5. vectra c 2003 2.2 dti cold start issue
    By sjs in forum Vectra C / Signum Car Chat
    Last Post: 25th November 2010, 14:59
