Thread: Multiple problems!
    Mar 2007
    Romania
    Default Multiple problems!
    I have multiple electrical problems with my car, put on the OP-COM and got the following error codes:
    DIAGNOSTIC REPORT:
    OP-COM 090714
    DT
    **********************ECU ID STARTS**********************
    Source Address: CIM
    Source Address: 0x00000245
    Identifier: 0x0015
    VIN: W0L0ZCF6921049904
    Part Number:13112784
    Software version number: 12244872_
    System description: DELPH0400
    Alpha code:
    Manufacturing date: 050128
    Number of stored fault codes: 2
    B3924 - Wrong Environment Identifier Received BCM (Body Control Module)
    (00) - Present
    U2107 - CAN-Bus no Communication with BCM
    (00) - Present
    **********************ECU ID ENDS**********************
    Source Address: ECM
    Source Address: 0x000007E0
    Identifier: 0x0201
    System name: Z18XE
    Hardware number:2004000
    Part Number:9179499
    Software version number: 6586085112
    System description: SIEM 0100
    Type approval number: S02001
    Alpha code:
    No fault codes stored.
    Source Address: ABS/TC/ESP
    Source Address: 0x00000243
    Identifier: 0x0301
    Hardware number:12790842
    Part Number:9191497
    Software version number: 00C32B2E
    System name: ESP EBC430
    System description: TRW 0300
    Alpha code: EP
    U2139 - Invalid Data from CIM (Steering Column Module)
    (71) - Present
    U2103 - No Communication with CAN-Bus (High Speed)
    (00) - Present
    Source Address: EHPS
    Source Address: 0x00000244
    Identifier: 0x0101
    Hardware number:24444336
    Part Number:0
    Software version number: V11_
    System name: EHPS GEN3 TRW
    Alpha code:
    Source Address: IPC
    Source Address: 0x00000255
    Identifier: 0x0200
    Part Number:9180273
    Software version number: 6.36 38/02
    System description: VDO 0400
    Alpha code: WB
    Manufacturing date: 020506
    (00) - Present
    U2105 - CAN-Bus No Communication with ECM (Engine Control Module)
    (7F) - Not present
    Source Address: AIRBAG SDM
    Source Address: 0x00000257
    Identifier: 0x0001
    Part Number:13129843
    Software version number: 00BA9224
    System description: DELCO0400
    System description: 0x41533938343348323231343141485930
    Alpha code: CL
    Manufacturing date: 020521
    Source Address: REC
    Source Address: 0x00000254
    Identifier: 0x0101
    Part Number:13125487
    Software version number: 0000038D
    System name: REC
    System description: LEAR 0400
    Alpha code: AZ
    Number of stored fault codes: 1
    (00) - Present
    Source Address: UEC
    Source Address: 0x00000253
    Identifier: 0x0101
    Part Number:13112918
    Software version number: 0000038C
    System name: UEC
    Alpha code: AK
    (00) - Present
    Source Address: DDM
    Source Address: 0x00000259
    Identifier: 0x0101
    Part Number:9227560
    Software version number: OP1D 186000
    System description: SIEM 0401
    Alpha code: KL
    Manufacturing date: 524020
    Number of stored fault codes: 3
    (00) - Present
    B1330 - System Voltage Malfunction
    (00) - Not present
    U2139 - CAN-Bus No Communication with CIM (Steering Column Module)
    (00) - Not present
    Source Address: PDM
    Source Address: 0x00000258
    Identifier: 0x0101
    Part Number:9227562
    Alpha code: KP
    Manufacturing date: 424020
    (00) - Present
    (00) - Not present
    (00) - Not present
    Source Address: DIS
    Source Address: 0x00000246
    Identifier: 0x0304
    Hardware number:13117635
    Part Number:13117636
    Software version number: 08.08.13.04
    Alpha code: AJ
    Manufacturing date: 020429
    (00) - Present
    Source Address: ECC
    Source Address: 0x00000248
    Identifier: 0x0104
    Hardware number:9228184
    Part Number:24441229
    Software version number: C313 0100101
    System name: ECC 3200
    System description: 0x33383831383420000200050003304333463500
    Alpha code:
    Some of my problems:
    Interior lights doesn't work, buttons on my key doesn't work, rear windows doesn't work, i can open the car only manually with the key, the lights panel doesn't work at all, but the car starts and i have no problems with the engine. Any clues?
    Admin plasma's Avatar
    On the Forum
    333 Post(s)
    Engine : 150
    Mileage : 74000
    most of these point to the BCM, check the fuses mate.. the BCM fuses are located left hand side of car open the door and a pull off flap on the end of the dash.
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
    Mar 2007
    Romania
    I did check all the fuses, the fuses from the engine compartment, the fuses of the BCM on the left side of the car (it is not a right side steering car, i live in Romania), also the REC fuses, all of them are OK. I also used a SPRAY CONTACT on most of the sockets/jacks...
    On the Forum
    333 Post(s)
    Engine : 150
    Mileage : 74000
    try a battery disconnect for 10mins, its the no communication with the BCM which is pointing me at it..
    Mar 2007
    Romania
    I did that also, i disconnected the battery for almost 3-4 hours, also the turn signals doesn't work, which is a very bad issue as i cannot drive the car without the turn signals...
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Check frequency reading at the can wires of bcm
    Check the bcm power an ground.
    Mar 2007
    Romania
    Can anyone provide the wire schematics or the 2 sockets/jacks PIN that goes to the BCM fuse board in order for me to check out the + and ground, in order to check out that the BCM module power up.
    There are 2 sockets, one that enters the Board with fuses where the bcm is fitted and other that enters in the BCM itself, so i need to know what wires or socket pins to verify for power.
    Thank you very much and excuse my poor english.
  1. Multiple Warning Lights!
    By alcno1 in forum Vectra C / Signum Troubleshooting
    Last Post: 3rd February 2010, 01:46
  2. How do i use same pic on multiple posts
    By sberrow in forum General Chat
    Last Post: 11th March 2009, 19:20
  3. Multiple Tech II readings
    By Ncompass in forum Vectra C / Signum Car Chat
    Last Post: 8th March 2008, 12:13
  4. IE7 - Multiple Home Pages
    By Merick in forum General Chat
    Last Post: 14th May 2007, 18:07
b3924 fault code vectra c
