Thread: Autobox snatching
    Regular Member 1.9Cdti Elite's Avatar
    Aug 2009
    Dawlish
    Vehicle : Insignia
    Trim : Elite 160 Navi
    Year : 2011
    Mileage : 38,000
    Default Autobox snatching
    Hi guy's, I hope someone can offer advice on this problem:
    While pulling away from stationary the auto box changes from 1st to 2nd and then just on the point of changing into 3rd it feels as though the gearbox finds a false neutral, engine revs climb because vehicle is under accelration condition and then gearbox dumps back into drive/3rd causing a snatching effect a bit like dumping the clutch on a manual tranny, it has spun the wheels in the wet. The car is an 06 Vectra c 1.9CdTi 150 Elite with 6 speed auto trans, any advice welcome before I take it to Eden at Exeter and feed them the keys.
    Wondering lonely as a cloud
    26 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    Get it looked at soonest might be lucky and just need an transmission fluid change but better checked before it does any damage, mine needed changing because I left it mine took a couple of seconds to select first when put into drive.
    Aug 2009
    Dawlish
    Vehicle : Insignia
    Year : 2011
    Mileage : 38,000
    Hi paulhb, it goes into drive ok but doesn't do this snatching thing all the time, it has been into Vauxhall and they say they checked the fluid level and said it was fine, they checked for a burnt smell and that was ok, they even took it for a 30 mile drive and said it was driving ok but when it's playing up like this it is nasty to drive.
    Full Member
    Mar 2007
    Finland
    I'd recommend to change the fluids anyway. And you could try also Lubegard Platinum, it should help with sticking valves etc.
    Aug 2009
    Dawlish
    Vehicle : Insignia
    Year : 2011
    Mileage : 38,000
    Thanks for the advice chaps.
    Nov 2012
    Bucks
    Vehicle : Vectrs C Estate
    Trim : Exclusiv
    Engine : CDTI 150
    Mileage : 70000
    any update on this - did you get it fixed? what was it? - I have the same car with exactly the same fault so would be very interested to know what happened!
    Aug 2009
    Dawlish
    Vehicle : Insignia
    Year : 2011
    Mileage : 38,000
    Quote Originally Posted by tnewbery View Post
    Hi tnewbery,
    It has been a while since last posting but the situation is still the same with the autobox, it's like it hits a false neutral and then just dumps it into gear by which time the rpm's have shot up because you are trying to accelerate, it can't be very good for the transmission.
    It has been back to the dealers for several issues since and has cost a small fortune, to date it has had: New front springs during MOT, New glow plugs, New inlet manifold and last week a new EGR valve, in the last 6 months the total bill is £1,500 ish and the autobox is still playing up
    Regular Member veclee's Avatar
    Nov 2012
    skegness
    Vehicle : vectra c
    Trim : club
    Engine : 1800
    Mileage : 63000
    Trans oil and filter change sounds like a sticking valve if not sorted soon you'll be needing a new box due to the bands burning out is the oil a clean colour or is they any black tinge to it most common faults with autos is people don't realise they need oil and filter changes every few years atleast once the main 3years of warranty. Servicing is done it gets left I've done my fair share of changing auto box's one of the main reasons I used to buy themspares or repairs box is slipping / snatching gears hth
    Sep 2010
    Plymouth
    Engine : 1.9 CDTi 150
    Year : 06
    Mileage : 250,000
    i had this with my 150 cdti, it was getting to be a real issue for me.
    Changed the trans fluid and to date have had no issues at all, the changes in general are smoother and i have found it doesnt 'dump' it into the next gear like it used to.
    Mine had done about 200K when it was changed, its now on 245K and is still smooth
  1. what autobox do i have
    By jimmywhu in forum Vectra C / Signum Car Chat
    Last Post: 29th May 2012, 07:42
  2. autobox
    By cajagoogoo in forum Engine & Drivetrain
    Last Post: 28th February 2012, 21:04
  3. Anyone done an autobox?
    By cphaza in forum Vectra C / Signum Car Chat
    Last Post: 7th February 2010, 23:20
  4. Autobox problem
    By 24vElite in forum Engine & Drivetrain
    Last Post: 26th January 2009, 21:48
  5. 3.2 autobox
    By poves in forum Engine & Drivetrain
    Last Post: 27th November 2008, 10:08
