Thread: Set my Vec on fire!!! Well a litle bit on fire
    Wetherby
    Default Set my Vec on fire!!! Well a litle bit on fire
    Well it was not as dramatic as it may seem, but I really could have done without it.
    After fighting to get the 12v unit out of the car yesterday, today I was in a position to hardwire in my sat nav’s power lead. So off came the dash and before fitting the wiring loop I plugged it all in to test and it worked. I had to unplug it to install it and once this was done I plugged it back in…….
    Powered everything up and I was instantly hit with the smell of melting plastic and huge plumes of toxic white smoke billowing from the dash. Oh Sh*t!!!!
    Well, I had connected the loop on backwards and in puff of smoke I had melted the power adapter for my TomTom. The cost of a new one? £20. Could have been worse.
    spoons
    Guest
    Nr Cardiff
    Oops!
    Regular Member murf2484's Avatar
    Apr 2006
    normanton west yorkshire
    what the. my god lucky it was just your tom tom power cable you fried id have died if id have done that
    Quote Originally Posted by murf2484 View Post
    RBK has a story about that I am sure he will be along with his How not 2 on hard wiring Tom Toms (Knew i`d get you back for that drunken photo )
    Sunny Aberdeen
    Quote Originally Posted by Bainie View Post
    Lets just say that the Tomtom is not run from a 12 volt supply ...
    p.s. note to Curry's : "My new Tomtom went pop all on it's own as soon as I plugged it in !! Honest" ........
    Regular Member cameraman's Avatar
    Leicester
    I've installed a couple of 12V sockets in my dash for this sort of thing, one for the sat-nav & one for the phone charger, scotchlocked them onto the back of the existing sockets & work A1. Tomtoms run on a 5v supply btw
    Wetherby
    Quote Originally Posted by cameraman View Post
    Yeap, thanks. I've got a tomtom incar kit with a 12v plug. What I've done is run a lead off the 12v point in the dash to a cig plug I got from Maplins and just pluged in the incar kit socket into it. This then runs the 5v USB point for the tomtom. Should have been easy!
    Leicester
    Same as I've done.............only I fitted mine the right way round
    At least it's only the power adapter you've fried
  1. 2.2 Mis-Fire
    By spennny in forum Engine & Drivetrain
    Last Post: 15th August 2012, 19:54
  2. Fire!!!!!!!!!!
    By the-wizard in forum General Chat
    Last Post: 18th January 2011, 16:48
  3. Fire
    By mspvxr in forum Comedy & Humour
    Last Post: 4th August 2009, 17:15
  4. Mis-fire
    By gothamvectra in forum Vectra C / Signum Troubleshooting
    Last Post: 8th October 2008, 20:13
  5. Fire, Fire, Fire
    By mushy2007 in forum Comedy & Humour
    Last Post: 15th November 2007, 23:18
