Thread: Calling all 2.0/2.2 DTI owners with silicone pipes!
    Birmingham
    Default Calling all 2.0/2.2 DTI owners with silicone pipes!
    Guys,
    I want to do a bit of preventative maintenance on my car as im certain there a problem somewhere but im struggling to find it (have a read here).
    The one that I have my doubts about is the BIG PIPE that goes to the EGR / Intake area and is situated at the front of the engine.
    Im thinking of changing this for a silicone one but need some help as to which one I need an where I can get it from. All the smaller vac pipes look OK and I have checked the ends of all of them.
    My car is a 2.01 DTI.
    Thanks.
    Bye bye Vec B
    - Hello Siggy!
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    Vaux man g have a look on E bay, just tap in (2.0 Dti silicone hoses)and you will find them .
    and still loving it
    Jun 2011
    wolverhampton
    Regardless what ya vac hoses look like change them. 3mm internal bore 3m long is enough to do the job. Remove and clean egr throughly. Remove and clean boost sensor with brake/carb cleaner only! All these are cheap to do and sorted all my random lights on dash and now drives better. If u have a split intercooler hose or suspect it is it will be obvious by loud hiss noise on boost and a split in the hose if you remove and inspect it
    Birmingham
    Good idea, might just do it for the preventative measure.
    Bye bye Vec B
    - Hello Siggy!
    Macclesfield
    Vehicle : Focus
    Trim : Titanium
    Engine : 1.6 TDCI
    Year : 62
    Mileage : 9K
    When you change the 2 large intercooler hoses, are they part of the radiator system? What im asking is, will you loose coolant when you remove the pipes?
    Macclesfield
    Vehicle : Focus
    Trim : Titanium
    Engine : 1.6 TDCI
    Year : 62
    Mileage : 9K
    Quote Originally Posted by Graham View Post
    Its ok, found my answer in the search bar. My car went into limp mode 3 times the other day pulling the caravan back home.
    It was only when i floored the pedal from 50mph to 60mph that it went to limp mode. Happened 3 times.
    So guessing i may have a split in my intercooler pipes somewhere.
    Mileage is 115k so probably need changing.
    Jun 2011
    wolverhampton
    Or vac hoses
  1. 2.2dti Silicone boost pipes fitted (photos included)
    By Innes in forum Diesel Engine related
    Last Post: 22nd August 2016, 22:05
  2. Blue Silicone Boost Pipes
    By smiley-sri in forum Parts for sale
    Last Post: 26th September 2010, 17:49
  3. Calling ALL 3.2 owners
    By big phil in forum Tuning
    Last Post: 29th April 2010, 13:11
  4. Calling all v6 owners i need help
    By dannyjpuk in forum Engine & Drivetrain
    Last Post: 23rd January 2010, 23:17
  5. Calling all dog owners!
    By NellyD in forum The 'Off Topic' room
    Last Post: 27th July 2008, 21:53
silicone intercooler pipe vauxhall vectra 2.0 dti pipe
