Results 1 to 3 of 3
Thread: Signum 2.0T EML light sometimes on
    leeds
    Default Signum 2.0T EML light sometimes on
    Hi Everyone,
    I have done 93K on my Signum without an engine problem but now I have the spanner EML light on. Sometimes it goes out but most of the time it is on now. Once the EML light has come on, the A/C will not work either.
    I had the codes read and there is P0495-00 which is cooling fan 3. I have confirmed the rad fans run on the slow and medium speeds but not the fast speed which I assume is 'fan 3'. Has anyone ever had this before?
    I think there must be relays controlling the fans and there are several under the bonnet in the fusebox but does anyone have any info as to what each of them does?
    Would be grateful for any ideas.
    David.
    South east
    At a bit of a guess, it could be a faulty coolant temperature sensor.
    Jun 2012
    Fife
    The faulty a/c is probably a rotten condenser, visable through the bumper.... if it looks wet, it's the a/c oil leaking....
    The engine fan is controlled through the engine bay BSI unit, and relays. You need it on a fault code reader that can do 'actuator tests', basically work the fan / circuit (or not if faulty)on full speed with the engine off (Without cooking the engine) and test the circuit to trace the fault.
  1. Should I Have A Spanner Light aswell as an Engine Light on My Signum?
    By StreetDragster in forum Engine & Drivetrain
    Last Post: 18th August 2012, 11:57
  2. The Signum see's the light!!
    By kman247 in forum Vectra C / Signum Car Chat
    Last Post: 24th September 2010, 13:54
  3. signum fog light surronds....
    By MAF 3.2 V6 GSi in forum Parts for sale
    Last Post: 1st November 2007, 20:58
  4. will a 07 fog light fit a 04 signum
    By eaglepva in forum Vectra C / Signum Car Chat
    Last Post: 18th September 2007, 08:11
