Thread: multi plug pin connector
    VIP-Member antowens's Avatar
    Dec 2011
    liverpool
    6 Post(s)
    confused multi plug pin connector
    is there and easy way to remove the pins from the back of the multi plug as i have had one snap on me its from the multi plug that goes into the radio i need to remove it to be replaced but cant for the life of me get it out anyone now which way to go with these or how to get them out ???
    Administrator plasma's Avatar
    On the Forum
    358 Post(s)
    Engine : 150
    Mileage : 74000
    if its the pin for the wiring harness you need to slide out the purple bits which are the secondary locks for the pins.. Then you need a removal tool (a very thin jewellers screwdriver should suffice) and slide it down the outside edge of the pin on either side and give it a little twiddle... as you slide it down it should push the locking tabs in allowing the pin to be removed from the back of the plug
    Dec 2011
    liverpool
    6 Post(s)
    its were my aux in cables connect to the multi plug that goes into the back of the radio one of them snapped on me so it aint gunna work until i get it sorted
    Dec 2011
    liverpool
    6 Post(s)
    does anyone know were i can get these connections from i cant find them anywere vauxhalls dont sell them an neither do maplin looking like i may have to go the scrappy cut a multiplug off another car
    Wirral, UK
    Vehicle : Mokka
    Trim : SE - Orange Rock 's !!
    Engine : 1.7CDTi
    I would ask these guys on ebay, they supply the pins and wire with the mod kits.
    http://www.ebay.co.uk/itm/Vauxhall-O...-/330772912346
  1. X26 Multi-plug, where is it?
    By Neve'o in forum Electrical & ICE (including SatNav)
    Last Post: 1st December 2012, 12:54
  2. CD30 connector plug problems
    By Taz69 in forum Electrical & ICE (including SatNav)
    Last Post: 12th September 2010, 21:55
  3. What Is This Plug/Connector For? (nr pollen filter)
    By ChrisBilly in forum Vectra C / Signum Car Chat
    Last Post: 29th April 2010, 18:43
  4. Headlight Connector/plug
    By Baz07 in forum Vectra C / Signum Car Chat
    Last Post: 16th March 2008, 19:04
  5. Unknown connector plug?
    By Ian T in forum Electrical & ICE (including SatNav)
    Last Post: 13th March 2007, 21:15
how to remove vectra blue locking pin from the wiring connector
vauxhall vectra multi connect
vectra c can plug in electrical connector
Vauxhall vectra multi plug
how to remove wires for 16pin plug on vectra c screen
where are they.multi.plugs on vauxhall.zafira
