Thread: VECTRA SRI CDTI 150 Back box
    Regular Member 150_SRI's Avatar
    Sep 2010
    Lincs
    Default VECTRA SRI CDTI 150 Back box
    Hi Guys,
    one of the brackets has rusted away on my back box and dropped off.
    its a vectra SRI CDTI 150 6 speed.
    called vaux and they want £374 just for the back box.
    called motor factor and they said £72 for a pattern part.
    Makes sense to go for pattern part. Any views on this / issues getting a non genuine back box?
    cheers guys
    Sodding Typical on Sea
    Does it have the stainless steel SRi trim? if so, BARGAIN!!
    Personally, I tend to go to a local garage and get a mils steel strap moulded to and welded around the back box to tie into the hanger again.
    Regular Member J P S's Avatar
    Sep 2011
    Birmingham
    Vehicle : 2007 1.9cdti sri 150 estate
    Trim : sri
    Engine : 1.9cdti 150
    its probably fixable if you go to an exhaust place?
    Sep 2010
    Lincs
    Yes it has the SRI chrome tip.
    Seen that one on Ebay but dont think its for a diesel as mine lookd just oval shaped.
    So do you guys think pattern part will be ok? So wont affect performance or anything like that?
    Sep 2010
    Lincs
    HI ALL WILL Any of the vectra C Backboxes for the facelift model fit the 1.9cdti 2007?
    or is the diesel back box diffferent to petrol?
    thanks
    It is OK to fit the back box from another engine, many on here do it with the twin outlet system from the 2.0t and 2.2 onto diesels
    Regular Member Lockstock2012's Avatar
    Aug 2012
    Bristol
    Just looked at my back box and the bracket is pretty rusted - can I hammerite it (just the bracket) ? Will this prolong the life of bracket? I assume being the back box heat will not be a major issue. Any tips welcome.
  1. CDTI is back and being run
    By Leemarksmith in forum Quick Photo Album
    Last Post: 7th December 2012, 18:45
  2. Cdti 150 back box
    By The Gas Man in forum Parts for sale
    Last Post: 21st February 2011, 22:47
  3. Power Socket in back of vectra CDTI 2006 facelift
    By 150_SRI in forum Vectra C / Signum Car Chat
    Last Post: 6th October 2010, 12:55
original vauxhall vectra cdti 150 2007 back box
