Results 1 to 10 of 14
Thread: EML light flashes on in 3rd, 4th and 5th gears around 2500 rpm then goes off?
    Midlands
    Default EML light flashes on in 3rd, 4th and 5th gears around 2500 rpm then goes off?
    Alright Guys, wanted some advice!
    I cleaned my EGR about a year ago after losing power randomly, then last week whilst driving i would randomly lose power for 10-20 seconds with an engine management light coming on and then it would dissappear again!
    The AA diagnosed it as the EGR valve and I had this replaced a few days ago, the car seems to drive much better now but I took it on the motorway and whilst accelerating through the gears I noticed that when i hit 2500 rpm in any of the gears 3 and above, the engine management light comes on but it doesnt affect performance, the cars continues to accelerate nicely and at 3000 rpm the light goes off?
    any idea what this could be guys?
    May 2006
    scotland
    Strange one (what engine btw?). If it were me, I would try and eliminate the EGR. The way I would do this: - I would disconnect the electrical connection to it (yes it will eventually throw up an eml and spanner but can be reset with a code reader upon re-connection or by simply driving around normally for a few weeks). This will render the EGR inoperative with valve in the closed position. You simply take the car out for a drive and observe its behaviour. If no change, then almost certainly not an EGR problem. If it is the EGR, some have stated on here that an ECU software flash update is available from VX for later EGR valves. Personally, I do not see why the need for this (but this is only gut feeling and maybe wrong). If an EGR has been re-designed, then it must be the valve aperture size that has changed. There is no electronic wizardry in one of these, the ECU controls the open\closing of the valve by electrical pulses to its terminals.
    Midlands
    Hi, it is the Z19DTH, yh it is strange I will try your suggestion but before then I will get a reader on it see what code is being bought up during the acceleration. The problem with your suggestion is that I won't notice anything? The spanner light is the only symptom of a problem as the car acelerates normally, if I discon egr spanner light will always be on lol
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Ensure that you have done this mod http://www.vectra-c.com/forum/showth...njector-wiring
    It may sort you problem it may not but it should b done regardless
    May 2006
    scotland
    Quote Originally Posted by Rizzy139 View Post
    No, the spanner will not be on all the time. The first time you drive, the spanner will be on all the time but after a few miles, the next time you restart the engine, the spanner light will go out once the engine has started and you will be left with the car emissions light on.
    Midlands
    Sorry dont think I clarified it enough lol, the spanner light flashes on when I start then goes off whichever is te stored code, the problem is whilst driving in the higher gears (3and above) every time I hit 2500 rpm spanner comes back on and then goes off at 3000 rpm? I am doing the vacuum hose fix Tomo will do the injector one too next week! Still waiting to get my hands on code reader lol
    Midlands
    I've just had a look at my injector, it already looks like the injector three in the last photo on the how2 not the first photo does that mean this fix or similar has already been done to my car?
    May 2006
    scotland
    Entirely up to you of course but I would for sure disconnect the electrical connector of the EGR valve, take the car for a run for approx 6 miles then on the way back, stop the engine and restart it. At idle now, the spanner light should be out and the eml light on i.e. normal apart from eml light. Then drive car and observe spanner light through the rev range you expect it to flicker on/off. If it still flickers, it is probably nowt to do with EGR. On the other hand if it does not flicker, its a good bet it is EGR related.
    My logic anyways.
    Midlands
    Cheers will give it a crack and get back to you, my boost pipes seem abit mashed do waiting on replacements to arrive will fox them first then diag the light!
    Jan 2010
    Trim : 1.9 cdti
    Engine : 120
    Year : 06
    If it is a z19dth with 0.5 written in a box on the lower part of the VIN plate, it sounds like the dpf is needing regen which it is not getting. Is the car used for short journeys by any chance?
  1. High level brake light flashes on and off?!?
    By frankiebdv in forum Electrical & ICE (including SatNav)
    Last Post: 25th February 2011, 20:29
  2. fault code ? 10-2-5-4 flashes ??
    By Ed100 in forum Electrical & ICE (including SatNav)
    Last Post: 10th December 2010, 12:31
  3. HID xenon canbus slim flashes when its on
    By marcovelocity in forum Electrical & ICE (including SatNav)
    Last Post: 18th September 2010, 12:15
  4. Engine management light flashes
    By rayco56 in forum Engine & Drivetrain
    Last Post: 6th October 2008, 09:38
  5. Oil light after 2500 miles???
    By rustywheelnut in forum Engine & Drivetrain
    Last Post: 12th June 2007, 07:46
https:www.vectra-c.comforumshowthread.php171088-EML-light-flashes-on-in-3rd-4th-and-5th-gears-around-2500-rpm-then-goes-off
