Thread: cigarette lighter blowing a fuse
    Aug 2012
    sunny cumbria (not)
    Default cigarette lighter blowing a fuse
    a mates cigarette light in his vectra C is constantly blowing a fuse.
    any ideas guys on why this is happening ?
    Dec 2011
    Seaham
    Is it blowing a fuse when the cigarette lighter is in it? As it sounds like it is shorting out.
    Check insode it for any debris.
    Aug 2012
    sunny cumbria (not)
    Quote Originally Posted by Ben50n View Post
    will ask him to check this Ben. and get back to you :-)
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    It's only blowing a fuse be ause it's shorting out. Just need to work out why lol
    Use a test light over the fuse. An disconnect parts of the circuit until light goes out.
    When light goes out that's the part of the circuit with short.
    But to start make sure no rust inside the actual power socket
    Aug 2012
    sunny cumbria (not)
    Quote Originally Posted by Critch View Post
    erm............ you've got me there Critch, test light? disconnect parts of the circuit? sorry but thats a different language to me LOL
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    It'll probably be as mentioned either debris in the socket or corrosion. Simplest way to narrow it down is to disconnect the plug from the socket assmebly, replace the blown fuse, and turn on the ignition. If the fuse doesn't blow then it's the socket at fault. Either investigate further or replace - a new socket isn't that expensive.
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Quote Originally Posted by ciderman View Post
    Haha sorry mate
    Just get simple bulb an some wore to make a test light.
    Then just disconnect the wires to See which one turns it out.
    Or as mentioned just disconnect power socket an replace fuse if it doesn't blow it's the socket
  1. Cigarette lighter socket wont work with lighter
    By Aaron1990 in forum Electrical & ICE (including SatNav)
    Last Post: 8th April 2012, 18:21
  2. No Cigarette Lighter
    By kingy999 in forum Electrical & ICE (including SatNav)
    Last Post: 20th February 2010, 21:46
  3. Cigarette Lighter
    By leeds vectra in forum Parts for sale
    Last Post: 6th January 2010, 23:35
  4. cigarette lighter fuse
    By redwon21 in forum Electrical & ICE (including SatNav)
    Last Post: 25th October 2008, 07:14
  5. cigarette lighter
    By slugo in forum Vectra C / Signum Car Chat
    Last Post: 9th January 2007, 19:35
vauxhall vectra cigarette lighter fuse location
signum cigarette lighter fuse
where is the fuse for the cigarette lighter in a vauxhall vectra c
cigarette lighter fuse vauxhall vectra
cigar lighter fuse in 56 Vectra
signum cigarrette ligjter fuse
vectra 08 fuses lighter
vauxhall vectra cigarette lighter fuse 2005
cigarette lighter fuse location on vauxhall vectra c
https:www.vectra-c.comforumshowthread.php171078-cigarette-lighter-blowing-a-fuse
opel signum cigarette lighter not working
cigarette lighter fuse signum 2004
vauxhall vectra cigar fuse
