Thread: Y22DTR fuel pump info?
    Engine : 1.9 CDTi
    Default Y22DTR fuel pump info?
    Has anyone changed the fuel pump on the Y22DTR engine?
    Is the ecu coded to it (Could I fit a second hand fuel pump ecu without Tech2)
    And how easy is it to get to?
    Admin plasma's Avatar
    On the Forum
    265 Post(s)
    Engine : 150
    Mileage : 74000
    no not changed one,
    yes its coded to the car, and no you cant fit another one without first of all having the donor one reset before removal or at least having the code for it to clear it once fitted to the recipient car
    its chain driven and due to labour costs to drop it all and take the chains off thats normally a factor in writing them off.
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
    Engine : 1.9 CDTi
    Any idea what normally goes wrong with them?
    If its just the fuel pump ecu can they be removed (like some others)?
    On the Forum
    265 Post(s)
    Engine : 150
    Mileage : 74000
    the fuel pump will still need to be removed if u want to change the ECU, have seem problems where the seals get leaky causing poor starting, have seen them not controlling the boost control solenoid, and heard of them not injecting/operating correctly causing it not to rev correctly...
  1. Vectra B y22dtr fuel pump interchanging codes?
    By RyanNI in forum Engine & Drivetrain
    Last Post: 22nd November 2012, 19:36
  2. 2.2 direct fuel pump and fuel pressure regulator
    By w111y in forum Engine & Drivetrain
    Last Post: 11th July 2012, 22:12
  3. Fuel Pump For Signum 2.2 DTi Y22DTR
    By countduckula55 in forum Vectra C / Signum Car Chat
    Last Post: 25th January 2009, 20:48
  4. Fuel pressure sensor/fuel pump failure list following Watchdog investigation.
    By happychappy in forum Vectra C / Signum Car Chat
    Last Post: 14th January 2009, 13:18
  5. Found this info. Torqe Values Vectra C Y20DTH , Y22DTR
    By andymagee1982 in forum Engine & Drivetrain
    Last Post: 20th October 2008, 01:18
y22dtr fuel pump
vectra 2.2 y22dtr pump
y22dtr engine info
