Results 1 to 10 of 18
Thread: 1.9cdti drain anti freeze and renew questions
    Regular Member Vectra-c-SRI's Avatar
    May 2008
    Near Glasgow
    Engine : 1.9cdti 8v (120bhp)
    Mileage : 98000
    Default 1.9cdti drain anti freeze and renew questions
    Hope you guys can help.....
    The full car takes 7litres, 3.5 anti freeze 3.5water
    The drain cap is on the drivers side of the rad.
    To bleed the air from the rad start the engine
    with bottle cap off for a few mins.
    To flush the rad, after draining, fill it up with water only and start engine and leave for 10min wait till cool and drain then refill with half half of anti freeze n water ??
    May 2008
    Near Glasgow
    Mileage : 98000
    Anyone ?
    11 Post(s)
    If you know the quantity of the cooling system, then it's best to flush the system with water and drain.
    Then put in neat antifreeze (half the amount of the total quantity of the cooling system) and top up with water.
    Remember, even draining ths system will leave a certain amount in the system. Heater matrix and lower half of the engine block for example. By flushing through with water will leave just water in the system that cannot be fully drained. By putting half the amount of antifreeze in first, then topping up with water will ensure a 50/50 mix.
    btw, it was mentioned in another thread that the 1.9 CDTi has 7½ litres in the system. My 2007 handbook doesn't mention it though.
    May 2008
    Near Glasgow
    Mileage : 98000
    So I drain it from the rad cap and and fill with water start the engine and drain again then put my 3.25litre of anti freeze in then 3.25litre of water then leave the cap off and run the engine for 10min with heater on but no fan to get air out ?
    11 Post(s)
    There should be a drain tap on the lower offside of the radiator.
    Drain coolant out. Pour water in header tank and allow to drain out through tap. Do tap up and fill system with water. Run engine to circulate for a short while.
    Drain again, and do tap up for the last time.
    Then put in your 50% of neat antifreeze into the header tank, followed by water.
    Run engine with the cap off and keep topping up until level settles. Squeezing the top and bottom hose can help. Level will considerably drop once thermostat opens.
    Fit cap once sure has correct amount in system.
    Go for a drive and check levels once more.
    Allow engine to cool and check level once cold. Top up with 50/50 mix if necessary.
    May 2008
    Near Glasgow
    Mileage : 98000
    Thanks for your time mate will do that just didn't want to mess it up lol
    11 Post(s)
    Just checked on autodata. The 1.9 CDTi (both the 120 and 150) have 7½ of coolant in the system.
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    Guys , for a proper flush and fill you don't need to do anything like drain plugs or jacking the car up etc.... You have a water pump, put it to use;
    Disconnect the rad return hose at the coolant tank end (small hose from rad top to coolant tank)
    Push the hose down so it's lower than the rad end
    Remove coolant tank cap
    start car
    wait for water to flow out of the rad return hose and out onto floor
    with a hose, keep the water level up on the coolant tank
    keep doing until water flows out return hose clear- meaning nice ad flushed...
    Once runs clear, stop topping up with water, let it run down a bit and then top up with correct amount of coolant
    Connect return hose and job done!! All you needed as pliers
    May 2006
    scotland
    Brilliant idea Antssssssss. How long approx would this take?
    Middlesex
    Trim : SRI
    Mileage : 100k
    20 mins I guess to ensure runs completely clear..
    Make sure you have the heater on hot too..
    Ive done this literally 100s of times and it's the way we did it in the dealers
  1. anti freeze help
    By neill in forum Vectra C / Signum Car Chat
    Last Post: 20th November 2012, 22:58
  2. anti freeze help please
    By amir2300 in forum Vectra C / Signum Troubleshooting
    Last Post: 11th January 2012, 01:02
  3. Anti freeze
    By prm in forum Vectra C / Signum Car Chat
    Last Post: 3rd August 2006, 21:24
  4. Anti-Freeze
    By Hendry in forum Vectra C / Signum Car Chat
    Last Post: 21st November 2005, 21:47
vauxhall astra coolant capacity
antifreez opel astra 1.9
antifreeze z19dth
vauxhall vectra 1.9 150 coolant capacity
vauxhall zafira 1.9 antifreeze how many liters
astra twintop 1.9 cdti how to bleed coolant
1.9 cdti air in coolant
zafira 1.9cdti coolant
z19dth coolant capacity
how to drain coolant from vauxhall zafira 08
vectra exclusiv 2006 replace antifreeze
vauxhall astra engine water capacity
vauxhall astra 1.7 cdti coolant capacity
2.0 cdti astra mk6 coolant capacity
astra 1.9 cdti coolant bleeding
coolant capacity zafira 1.9cdti
how to bleed coolant astra 1.9 cdti
vauxhall vectra cdti sri 1.9 antifreeze
opel zafira 2006 1 9 cdti antifreez quantity
astra h coolant capacity
coolant capacity vevtra 1.9
zafira coolant bleeding
how to top up the coolant on a vectra
vauxhall zafira antifreeze
topping coolant up in a vauxhall zafira 1.9 cdti
