Thread: ABS and TC lights on
    Regular Member paul-west-76's Avatar
    Feb 2011
    wolverhampton
    Vehicle : signum 1.9 cdti 150
    Trim : elite
    Engine : 1.9 16v
    Mileage : 125000
    Default ABS and TC lights on
    Well after 12 + months of trouble free driving, the abs and tc lights came on yesterday when exiting an island, so just wondered if anybody had any quick fixs or ideas what it could be before i get it looked at. not had any work done on any brake components recently. cheers.
    Jan 2012
    Milton keynes
    Trim : M Sport and Design
    Mileage : 38100
    Guessing the lights are on permanently?
    Have you tried disconnecting the battery to see if it clears?
    If so, I'd say you have a problem with an ABS wheel speed sensor. This affects both ABS , TCS and ESP.
    Try the car battery first, then if that fails, look in the manual at the fuse / relay list, give those a check... then try disconnecting the Hub connections and make sure they are clean and dry...
    IF you still have a fault... I'd say its a new hub time... best to go to a garage with Tech2 so they can tell you which one. Very easy job (just done it to mine) maybe 2 hours max and the part from Ebay is pretty cheap.
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Best bet Is getting it on diagnostics.
    Dies t need to be tech 2 any professional level tool does abs these days. So should find fault fairly easily
    Feb 2011
    wolverhampton
    Trim : elite
    Engine : 1.9 16v
    Mileage : 125000
    cheers, i will have a look later and let you know. thanks.
    Regular Member Mushy's Avatar
    Oct 2010
    Dunbar
    Vehicle : vectra c
    Trim : sri
    Engine : 1.9 cdti 150 BHP
    Mileage : 98000
    i had same problem .it was the wiring to senser needed fix cost me £109.
    May 2006
    scotland
    As said above, it does not always mean a sensor fault. Quite often it is moisture in the wiring that causes corrosion and then faults develop.
    Devon
    If it clears itself once you turn the ignition off and on, the next time it happens check to see if the indicators still seIf cancel. If they don't then itís your CIM playing up.
    Feb 2011
    wolverhampton
    Trim : elite
    Engine : 1.9 16v
    Mileage : 125000
    hi, tried battery but no joy, also indicators work fine so check fuses and connectors tomorrow. cheers.
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Pay the 20 quid or so in a garage get codes read it'll make life a lot easier
    Jan 2012
    Milton keynes
    Mileage : 38100
    Quote Originally Posted by Critch View Post
    I'd be inclined to agree with critch.... let the computer tell you whats wrong and hopefully its the cheapest fix
  1. Brighter Lights for side lights, Vectra SRI150
    By 150_SRI in forum Vectra C / Signum Car Chat
    Last Post: 13th July 2011, 23:50
  2. Replies: 2
    Last Post: 31st March 2010, 13:30
  3. Philips bluevision h7 head lights & side lights brand new
    By davidlewis24 in forum Parts for sale
    Last Post: 19th March 2009, 22:42
  4. Dark lights and Rear Lexus lights finally fitted
    By Leviathan in forum Styling
    Last Post: 29th February 2008, 22:35
