Thread: Alarm goes off randomly-have fault codes
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Default Alarm goes off randomly-have fault codes
    Hi all,
    my alarm has been going off randomly and even brought up a dash warning light.
    The codes I have are:
    B3916 - No Communication With Alarm Siren (bit strange because I am sure the siren works when the alarm goes off)
    B3803 - Comfort Closing Low Voltage or Circuit Open
    B2966 - Driver Doorknob Circuit Open or High Voltage
    I think B3803 is a common fault and would not start the alarm.
    Whats the driver doorknob circuit, is it linked to the handle or something?
    Car is 2005 full canbus hatchback 1.9 CDTi 150 prefacelift
    Northampton
    Engine : A20DTH
    Mileage : 88000
    alarm went off again last night
    The code that showed up this morning is B2966 driver doorknob circuit
    so what itm is faulty and where is it?
    Devon
    75 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Think B2966 driver doorknob circuit is related to drivers door module mate,think its telling car door is open so could trigger alarm
    Irmscher Insignia CDTI 130
    Regular Member MrDerv's Avatar
    Nov 2011
    North East (Beamish)
    Check the wiring channel from the body to door, may be frayed wires causing a short, or a faulty door module in the door itself.
    Administrator plasma's Avatar
    On the Forum
    357 Post(s)
    Engine : 150
    Mileage : 74000
    none of them would be setting the alarm off.... drivers door knob one has been present on many a car i've checked. currently present on mine, i believe its something to do with when the door knob is pushed down it then locks all the other doors...
    you really need the alarm codes, they are stored under the BCM i believe
    ps. if there was anything wrong with the door wiring your courtesy light wouldnt be working when the door open/closes...
    Northampton
    Engine : A20DTH
    Mileage : 88000
    no codes reported under the BCM
    I will wait for it to go off again.
    When it started to go off a week or two back it brought up a dash warning light. The dash warning light went off once the engine started so it was something that was recorded but not present again.
    On the Forum
    357 Post(s)
    Engine : 150
    Mileage : 74000
    there is a seperate section which opcom cant see mate... only tech2 can see it... (think vauxcom maybe can but couldnt when i owned it) lists the actual reason for trigger of alarm including the time/date stamp as well and alarm codes will not bring up dash warning lights lee
    Northampton
    Engine : A20DTH
    Mileage : 88000
    cheers for the info Dean, I will have to go to VX to get the codes read then
    not sure what the dash warning light was then, coincidental? Just strange it came on twice after the alarm was triggered
    On the Forum
    357 Post(s)
    Engine : 150
    Mileage : 74000
    or pop into trax at the weekend.. sending pm now..
  1. Alarm going off randomly
    By reesrk8 in forum Vectra C / Signum Troubleshooting
    Last Post: 6th March 2013, 21:04
  2. Alarm Randomly going off???? - Vectra 2006 Estate
    By TheSnowMan in forum Electrical & ICE (including SatNav)
    Last Post: 18th July 2012, 14:13
  3. alarm fault findind
    By neil29 in forum Vectra C / Signum Troubleshooting
    Last Post: 10th June 2012, 20:24
  4. fault codes
    By fiend61 in forum Vectra C / Signum Car Chat
    Last Post: 12th February 2012, 18:41
  5. Fault code - alarm
    By zafira in forum Electrical & ICE (including SatNav)
    Last Post: 25th March 2011, 13:07
