Results 1 to 10 of 17
Thread: fault codes DPF and Air intake Leak
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Trim : Smart and Bad!
    Mileage : 105000
    Default fault codes DPF and Air intake Leak
    Got 2 fault codes coming up now.
    P1901-75 for Particulate Filter Pressure Sensoor High Differential Pressure
    and P2279-11 Intake Air System Leak Detected
    I cannot find this leak as i checked it all over the intake and no leaks as far as i can see. used washing up liquid as i use the same thing for finding gas leaks as a plumber.
    Any assistance? would help a lot!
    I have resetted the PFP as it was at 110% and blueish smoke but no oil or water or fuel smell in the smoke, just emission smell. so i know no seals are lost or water in fuel or overfuel burn.
    Engine : 1.9 CDTi
    Clean the egr valve as that code also comes up when it doesn't fully close.
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    The egr valve been deep cleaned 200 miles ago. The inner valve opens and closes with smooth ease.
    I checked with my computer and reset the fpf it was at 110% so way over where it should be at!!
    I reset it to 0% to get more acuate reading. Tomorrow i'll check then after a drive.
    Can someone tell me the areas the intake air hoses as i checked, cant find any leaks so i might be missing one more hose??
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    New dpf on ebay but for vauxhall zafira 1.9cdti
    Any chance this'll fit vectra c??
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    See photos. Help me out guys :-((
    scottish region
    Get rid of the dpf mate and remap at same time you will only get this problem over and over
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    I would remap if the remapper actually tell me clearly. If i was to have it removed then get it remapped, they keep saying no remap possible if in regen... How am i to know when car doing regen? Am confused really. Cant afford 599 for dpf removal, ecu dpf delete and remapping...
    Could you lovely members of the great forum Explain in steps what i need to do to safe money as much as possible please? I'll love you all more if you do help!!! :-O
    scottish region
    If u get dpf gutted then a pipe put in place then get a remap with all ash levels reset and dpf removal software you will be fine I got it done last week can pm you the details as its a nationwide company
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    Quote Originally Posted by DAVIDD88 View Post
    How much did it cost u? Gutting the dpf how??
    scottish region
    I was 575 including the dpf gutted and pipe put in as far as everyone knows the dpf is still there as sensors and dpf are still present
  1. P2279 Fault Code - Ait Intake Leak
    By McLovinH in forum Engine & Drivetrain
    Last Post: 20th September 2012, 17:54
  2. Air In intake Leak fault CDTI 150
    By rollercoaster63 in forum Vectra C / Signum Troubleshooting
    Last Post: 26th August 2012, 21:00
  3. intake leak
    By Richard.roberts in forum Engine & Drivetrain
    Last Post: 22nd November 2011, 22:14
  4. Intake air Sys Leak 1.9 CDTI
    By TonyTM in forum Engine & Drivetrain
    Last Post: 5th May 2010, 20:20
  5. EGR valve and Intake air leak
    By iceeee in forum Vectra C / Signum Troubleshooting
    Last Post: 8th March 2010, 23:19
air intake fault dpf
vauxhall zafira air intake leak
dpf leak fault code
fault codes vauxhall zafira air intake
p1901 cdti start problem
