Results 1 to 10 of 16
Thread: Brake wear sensor put where?
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    Default Brake wear sensor put where?
    Hi Guys
    im about to change the front breakes due to one warped disc.
    as ive never change disc and pads before on my car.. im wondering where the sensor goes? as i can see any "slot" on the new pads were to put it..
    (havnt started changing yet... but on it saturday)..
    (ive got new zimmermann disc and pads).
    And i dont fancy just cutting it off and bypassing it..
    Any pictures..
    morecambe
    44 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    There is a slot on the front passenger pads mate
    Regular Member keefy*2010's Avatar
    Jul 2010
    Grain, Rochester,Kent
    Vehicle : Vectra C Facelift
    Engine : 1.9Cdti 150
    Quote Originally Posted by paulvectrac View Post
    Just done all 4 discs and shoes on both wifes Signum pre facelift and front pads have notches in backplate of pad. On my Facelift Vectra there is no brakewear sensor part of cost cutting not mentioned in Elite specification.
    Engine : 2.2 Direct
    humm where pictures
    Regular Member Neve'o's Avatar
    Norfolk
    Vehicle : Vectra SRi 150 Hatch
    Mileage : 69'000
    is it not the holes in the pad back plate in your last photo? That's where they usual sit on most vauxs I have done in the past..
    Engine : 2.2 Direct
    Thats what i dont know... i can make the hole all the way through.. but as said ive never tried that operation before.
    Jul 2010
    [QUOTE=kenp;1879295]humm where pictures
    [/ JPG 4 If YOU LOOK AT 1 PAD YOU SEE A U SHAPE IN THE METAL BACKPLATE AND THE FERODO PAD THIS IS THE PAD NEAREST TO THE ENGINE AND THE WIRE AND SENSOR COME THROUGH THE BACKPLATE OF CALIPER QUOTE]
    Engine : 2.2 Direct
    ahh so i just have to make the "u-shape" through the back plate, as you can see on picture 3 its not all the way.
    Jul 2010
    Quote Originally Posted by kenp View Post
    I have bought pads for both my wifes Siggy (2003)(pre facelift) and my (2007)(facelift) Vetra both have same part number but early 2002 model Vectra's had type 1 caliper which looking at Haynes manual are different to the ones I fitted this week-end The actual sensor is in a grommet type housing that clips into the small "U" shape cut-out I will photograph the old pads I removed yesterday plus scan the pages from Haynes to show you the different calipers tomorrow morning as I need to charge Digital camera up and put it through photoshop on wifes computer thus annotating the photos for you. All front brake pads in UK have the "U" shape cut-out
    Engine : 2.2 Direct
    ill find out what i have on the car... when i take the old ones out......
  1. Brake wear sensor. Should my car have one?
    By Big Dave in forum Suspension, Wheels & Brakes
    Last Post: 22nd May 2013, 10:40
  2. Brake pad wear sensor
    By dittohead in forum Suspension, Wheels & Brakes
    Last Post: 14th July 2010, 22:20
  3. brake wear sensor
    By dazza2393 in forum Suspension, Wheels & Brakes
    Last Post: 17th June 2010, 22:30
  4. Brake wear sensor
    By Guyver1 in forum Vectra C / Signum Car Chat
    Last Post: 2nd December 2008, 20:33
vectra c 2007 front brake wear indicator
